Aero port placement - Car Audio Classifieds!
Old 01-23-2016, 05:53 PM
crownvicon26's's Avatar
0/11 sssss1882
Default Aero port placement
Trying to run 3 zv3 15's in the trunk of a crown vic. Dimensions will be 41w 23t 23d. Plan on using a 10" aero port 14" long @ 33hz. Sub and port back is loudest in these cars but I don't think I have space on the baffle to do that. My question is should I fire the port to one of the sides or fire it up being that my rear deck is ported?
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 01-24-2016, 06:07 PM
0/11 sssss1882
Any opinions. Sub up port back is another option but figure it wouldn't be as loud.
Taramps 8k
2 Zv.3 15's
Old 01-24-2016, 06:25 PM
0/11 sssss3526
In small cars, I know side aero works well. Not sure about a large car.
Old 01-24-2016, 06:45 PM
0/11 sssss1882
I was thinking this also. I'm totally lost on where to put the port.
Taramps 8k
2 Zv.3 15's
Old 01-24-2016, 07:06 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
I seen a few Lincoln town cars put up some good numbers with subs up and port back.
If you put the port to the side you can always flip the box and try the port on driver or passenger side and see which works best.
Old 01-24-2016, 07:19 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
Subs back, port driver should get loud as hell.
I'd do that before subs up, and port back in a trunk.
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
The Following User Says Thank You to FocusOn20s For This Useful Post:
crownvicon26's (01-24-2016)
0/11 sssss1882
I would consider sub up port back. Box will be built in the trunk so I wouldn't be able to flip it.
Taramps 8k
2 Zv.3 15's
Old 01-24-2016, 07:23 PM
0/11 sssss1882
10-4
Taramps 8k
2 Zv.3 15's
Old 01-24-2016, 09:04 PM
0/11 sssss1882
Up top
Taramps 8k
2 Zv.3 15's
Old 01-24-2016, 11:09 PM
KickinBlazer's Avatar
0/11 sssss1122
yea try side ported.....and forward ported...lol....just anything to make it fit!!
if its to loud your to old!
port type/ port placement from rear hatch Joe562MMA General Car Audio Discussion & Questions 1 05-26-2013 02:26 AM
port placement Xtremelegend General Car Audio Discussion & Questions 4 05-05-2010 08:16 PM
port placement mmwwjr Enclosure Discussion & Design Construction Help 7 04-24-2010 06:38 AM
sub/port placement? Ryan1126 General Car Audio Discussion & Questions 20 04-01-2010 05:45 PM
