3 10's vs 2 12's 4th order - Car Audio Classifieds!
Old 01-29-2016, 11:19 PM
KickinBlazer's Avatar
0/11 sssss1122
Default 3 10's vs 2 12's 4th order
ok guys and gals its 3 lower power 10's lower excursion capability to...vs 2 high excursion higher power 12's ....the 10's will be pushed to there limit ...the 12's wont be pushed as hard both will have a 3+ :1 ratio the 10's will have slightly more cone area it will be in a trunk 4th order no trunk wall the enclosure will be built in the car...and sealed off inside the trunk
if its to loud your to old!
Old 01-29-2016, 11:26 PM
mega fatty
0/11 sssss6008
I would do the 10's but that will really limit any power upgrades for the future
Old 01-29-2016, 11:37 PM
0/11 sssss1122
i have a audiopipe apk 4500 on tap and the 10's can be built for 1500rms each...so i can allways upgrade power....but the 10's will see a final load of .44 and the 12's will see a fina load of .66....so the 10's have more potential to get loud...or do they? i have no idea on 4th orders
Old 01-30-2016, 12:39 AM
0/11 sssss1417
I'd do 2 better 12s. Wire them to .5 or .66
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Old 01-30-2016, 01:18 AM
0/11 sssss1122
i got 1 vote for 3 10's and 1 vote for 2 12's....anyone else?
Old 01-31-2016, 09:56 PM
The_Dealer's Avatar
0/11 ssssss212
Can't speak for a 4th order, but I overpowered the fawk out of 3 Diamond Audio d3 10's on a [email protected] ohm after rise. Rated at 400w each, they were getting 730ish a piece and didn't skip a beat.
I say go with 3 10's. You have more wiring options, and a smaller box. Most 10's need 1-1.25cuft each so you're around 3.75-4cuft, which saves some space over 2 12's. Besides everybody likes a 3some, they're just so much fun.
The D3's are more Sq oriented, but they got loud and sounded awesome. That's one setup I wish I still had. I couldn't imagine how nice 3 dc level 3 10's would be.
Sent from my Motorola 2950 Special Edition 3w.
Old 01-31-2016, 10:00 PM
0/11 sssss1122
I love 3 10's setups but this won't be with dc lvl 3 10's...it will be with 3 custom 10's prolly 30+lbs each and will be in a 3:1 ratio 4th order iv ran nothing but sealed and ported boxes so it's time to do a 4th order
Old 01-31-2016, 10:25 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
If the 12's have higher excursion then you'll have more displacement with the 2 12's than the 3 10s once you change from looking at it in 2 dimensions to 3 dimensions... also, cone depth would come into play if you were banking on a vs cone area debate. Personalmy I'd take the tsps of both and decide based on those what would be better suited in a 4th
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 01-31-2016, 10:51 PM
0/11 sssss1122
the 10's would be better suited in every way then...and ratio wouldnt be a problem in either setup...but the 10's would have a 3.3:1 ratio and the 12's would be 3.1:1
Old 02-01-2016, 02:26 AM
0/11 ssssssss5
i would to the 2 12's. you can always add more power later. if your looking at cone area your only talking about 9 more square inches not really a difference, now motor force wise you might have more.
anyway kind of subs are talking about? looks like the 12's are a little more higher end than the 10's
4th order vs 6th order mikeredam General Car Audio Discussion & Questions 6 06-06-2013 11:03 PM
