4th. Order questions - Car Audio Classifieds!
Old 02-22-2016, 03:22 PM
0/11 sssssss11
Default 4th. Order questions
I'm going to be building a 4th for 2 zv4 18's with spl cones. Going 5.5 sealed and 11 ported tuned to 50hz. How much port area should I do?
Old 02-25-2016, 01:32 PM
0/11 sssssss11
Bueller Bueller Bueller
Old 02-25-2016, 03:27 PM
200 in^2 is probably the very minimum I would use.
Old 02-25-2016, 03:32 PM
0/11 sssssss11
How much more could I go?
Old 02-25-2016, 04:55 PM
FocusOn20s's Avatar
'12 Focus Bangin
0/11 ssssss951
50% cone area up to 75% has been used with success
2012 Ford Focus
Ampere Audio | SounDrive | Royal Excelene | STP Atlantic | Digital Designs
Old 02-26-2016, 09:21 AM
With that size chamber once you get around 300 in^2 the port length will probably become an issue, both in physically fitting it inside the enclosure and eating up too much space from the chamber volume.
4th order wall questions bumpinsubaru Enclosure Discussion & Design Construction Help 3 01-11-2015 06:30 PM
new guy from nebraska have questions on a 4th order uniefresh402 New Member Orientation 3 10-06-2012 09:34 PM
4th order questions maverickdog8 Enclosure Discussion & Design Construction Help 7 05-16-2012 09:47 PM
Single 15" 4th Order Bandpass Questions...1.5ft^3 sealed&3.5ft^3 ported? Jdubs04ss Enclosure Discussion & Design Construction Help 14 03-10-2012 12:40 PM
