98 c1500 ext cab wall 4 15in soundqubed cut sheet needed - Car Audio Classifieds!
Old 02-22-2016, 11:26 PM
0/11 ssssss132
Default 98 c1500 ext cab wall 4 15in soundqubed cut sheet needed
Wanting to build a wall for 4 15 inch Soundqubed HDS 3:15 in the back of a 1998 C 1500 extended cab wanting to tune box to around 32 any suggestions on box cut sheet
Tags
c1500, soundqubed, walled
I cut a sheet of mdf graham Enclosure Discussion & Design Construction Help 95 02-23-2016 09:13 PM
Ext. Cab vs Reg cab 90s S10 rachidfunaki Enclosure Discussion & Design Construction Help 13 02-15-2016 03:32 AM
i need a cut sheet for 2 sa12's mineralgrey01gt Enclosure Discussion & Design Construction Help 0 12-01-2010 12:44 PM
Is my cut sheet right? SQL Monte Enclosure Discussion & Design Construction Help 4 06-29-2010 09:32 AM
need help w/ cut sheet? SacTownBully84 Enclosure Discussion & Design Construction Help 8 04-12-2010 09:00 AM
