Front Firing or Side Firing port (Pictures inside) - Car Audio Classifieds!
Old 04-01-2016, 09:57 AM
0/11 sssssss11
Default Front Firing or Side Firing port (Pictures inside)
Its a Sundown E10v3 on 600 watts. Box is 1.28 cubes net @ 30hz with a 4 inch precision port. The car is a 99 civic.
My goal is to get low. I plan to have the sub firing into the cabin with the seats up most of the time.
I was wondering if I should take the time to get custom work done to incorporate a 90 degree elbow and have the port also firing into the cabin which is location B in the picture or if it would be sufficient if I side fired with either port position A or C.
Of course I'd like to have the most SPL out of this application too. I'm just wondering if I should take the time and effort to fab a front firing port or just go the easy route and do a side firing port and either location A or C
Old 04-01-2016, 09:59 AM
massivespl's Avatar
0/11 sssss8409
In trunk cars I've played with forward works good if u seal it off 100% or rear firing to get better lows.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-01-2016, 10:03 AM
0/11 sssssss11
I guess I should clarify that by no means am I trying to get loud outside the car. This system is 100% for me and my passengers. I'm trying to keep all the bass contained within the car.
I do understand firing rear is best but I am trying to eliminate trunk rattle, and I'm sure this system will already be plenty loud enough for me even just facing into the cabin.
I might flip the box sideways so I can get the best of both worlds but in the end I still need to figure out port placement.
Old 04-01-2016, 10:08 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
How about firing the port to the side and doing a trim panel on the back of the box sealing it from the trunk to avoid trunk rattle?
My game is legit,
Old 04-01-2016, 10:27 AM
0/11 sssssss11
Damn thats not a bad idea actually...I might entertain it
Would you still do a side port even without the sealing back trim piece?
Old 04-01-2016, 10:31 AM
doug118's Avatar
0/11 sssss4674
I've had 2 trunk cars and I liked the way they sounded when firing towards the trunk versus firing forward. One was sub and port on the same baffle and the other was port to the side. The 2 builds were like 4 years apart and different cone area so I can't really compare them to eachother as far as port location
massivespl's Avatar
0/11 sssss8409
Rear firing usually plays lower because the woofers load off the trunk and the wavelength is longer to the front of the car. You didn't say anything about eliminated trunk rattle in your first post. And you have a single 10" woofer... Your trunk should be fine
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-01-2016, 10:33 AM
0/11 sssssss11
Originally Posted by massivespl View Post
Rear firing usually plays lower because the woofers load off the trunk and the wavelength it longer to the front of the car. You didn't say anything about eliminated trunk rattle in your first post.
This system has yet to be built. I only have the sub at the moment. I'm in the process of getting the box built but I wanted to sort this last detail out.
I would just like to avoid rattle at all costs is all.
Old 04-01-2016, 10:36 AM
massivespl's Avatar
0/11 sssss8409
Deadener and spray foam to fill holes.
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-01-2016, 10:47 AM
massivespl's Avatar
0/11 sssss8409
4th order and port thur rear deck
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Front firing or rear firing? Beerdrnkr General Car Audio Discussion & Questions 9 08-09-2014 12:21 AM
Side firing port all4spl Enclosure Discussion & Design Construction Help 27 02-09-2013 04:16 PM
Suv side firing port question? murderedtahoe General Car Audio Discussion & Questions 7 11-27-2011 03:17 PM
Subs firing back...round ports firing forward? jstjst General Car Audio Discussion & Questions 6 07-07-2011 07:37 AM
Side firing in SUV jt_buck Enclosure Discussion & Design Construction Help 38 12-02-2010 10:46 AM
