1:1 or 2:1 fourth - Car Audio Classifieds!
Old 04-07-2016, 03:58 PM
0/11 ssssss308
Default 1:1 or 2:1 fourth
Im brainstorming enclosure types for my upcoming project and was wondering how much space is needed for two 15's in a 2:1 or 1:1 fourth order. Here are some subs that i have in mind
zv4
ampere 3.0v3
nightshade
team fi
sp4
Old 04-07-2016, 05:19 PM
Typically you'll need about 1.5-2 ft^3 per sub for the sealed section to get a resonance around 40-50hz.
There is no purpose in building a 1:1 4th. The space could be used more wisely.
Old 04-07-2016, 05:37 PM
e46inperrycounty's Avatar
SPL Farms
0/11 sssss5706
Fully agree with previous statement, a 1:1 has 0 gain. Might as well just do ported at that point.
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-07-2016, 06:02 PM
0/11 ssssss308
im just trying to get a better understanding of everything. so i will pretty much need 2 cubes per sub, so that will be 4 cubes sealed. Then i will multiply that times two, which is 8 cubes ported..correct?
Old 04-07-2016, 06:21 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Yea, looking at 4 cubes sealed and 8 ported..
Sent From My Phone
Old 04-07-2016, 06:26 PM
0/11 ssssss308
ok so with that being said how many cubes gross after displacements?
Old 04-07-2016, 06:51 PM
SPL Farms
0/11 sssss5706
Depends on sealed side baffle thickness, outside enclosure thickness, and loading wall thickness as well as port size/depth if internal porting and woofer choice
2 Ampere 3.0v2 18's
BC5500 at half ohm
Mark Antony gs380.4
Anarchy 6.5s
AB sq6b's
Team SPL Farms
Old 04-07-2016, 07:13 PM
0/11 ssssss308
I don't know if I have that much space work with without completely chopping up my car. I considered a fourth just to move the sound out the trunk and into the cabin of the car. I'll be running a lot of power to whatever subs I get
Old 04-07-2016, 07:51 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Sealed off ported enclosures work great..
Sent From My Phone
Old 04-07-2016, 08:18 PM
0/11 sssss1417
Read this thread.
4th orders why are some people so quiet with them?
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Dats an fourth question DC98hoe General Car Audio Discussion & Questions 20 11-20-2014 05:45 PM
fourth order for two 15's chevy454 General Car Audio Discussion & Questions 1 03-24-2014 04:43 PM
sundown trunk fourth dirtrider Enclosure Discussion & Design Construction Help 15 05-07-2012 09:26 PM
fourth and or sixth order help imlouder Enclosure Discussion & Design Construction Help 0 01-13-2012 03:24 PM
DC's in Fourth Orders? Nebraskachevy (DC) 13 03-06-2011 09:49 PM
