What should I use to seal the end of my port - Car Audio Classifieds!
Old 05-04-2016, 10:03 AM
0/11 sssssss60
Default What should I use to seal the end of my port
So I want to shrink my port volume and was going to add 1/2" sections to either side of the port. What sort of material should (or could) I use to coat the ends of the port so they look like one piece. Can I use a body filler or something like glass bondo on the ends and sand it down?
Any recommendations or tips would be appreciated.
Old 05-04-2016, 10:16 AM
0/11 ssssss275
Personally I'd use mdf with a roundover bit. That would be the cleanest look
Old 05-04-2016, 10:32 AM
0/11 sssssss60
Sorry should have noted if it makes any difference. The port is made out of birch. I will be using 1/2'' birch on both sides of the port walls to reduce the volume. So you think just using glue with a round over?
Old 05-04-2016, 10:35 AM
0/11 sssss1475
Bondo is your friend, it's easier to sand it smooth before it fully cures.
99 s10 Blazer 2 door 5.7L Vortec swap
4- Team Ascendant Audio 18's
4- Ampere 8.0 TFE's
2- Zed Leviathan's
20 banks Maxwell caps
Team Ampere - Team Heavy Flex +160dB
The Following User Says Thank You to lunchbox For This Useful Post:
Hhug19 (05-06-2016)
Old 05-04-2016, 02:29 PM
0/11 sssssss60
So "glass bondo" would work? This will be my first attempt at doing such an endeavor so again, I'm open to any tips! Thanks for the input.
Old 05-19-2016, 02:59 AM
The_Dealer's Avatar
0/11 ssssss212
I've done it before using 1/2" pieces of mdf screwed/glued to the port wall. I filled gaps between the pieces with wood glue & saw dust paste, then sanded it and went over it with bondo, then sanded again. After I was done you couldn't even tell.
I've even thrown a whole box on the table saw and cut a whole panel off, cut the depth down 1/2", then reused the panel. Couldn't even tell. You can add another baffle that covers the whole face of the box and use a router with a flush trim bit to cut your new(smaller) port
Sent from my SM-G900A using Tapatalk
The Following 2 Users Say Thank You to The_Dealer For This Useful Post:
Hhug19 (05-19-2016), lunchbox (05-19-2016)
Single high end 8" or dual lower end 8's? Vmax911 General Car Audio Discussion & Questions 12 07-02-2015 11:03 PM
How to seal this off? nobutada55 General Car Audio Discussion & Questions 0 10-27-2013 02:49 PM
Poll - Do you account for port end correction KingPen General Car Audio Discussion & Questions 24 02-25-2013 06:20 AM
WTT high end 12s for low end 15s tony30cl Car Audio Trader (WTT) 21 11-01-2012 09:48 PM
How close can a port end be to a wall? laextreme5 Enclosure Discussion & Design Construction Help 7 02-26-2012 12:07 PM
