Which design should i got with? - Car Audio Classifieds!
Old 05-10-2016, 12:18 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default Which design should i go with?
this is gonna be for 2 soundqubed HDS208's on 1200-1500 watts.
First design, lower tuning, but port area is lower:
second design the port area is better, but cant get tuning lower as i can only get 6" in up to a 24" length.
if the 2 4" will work i would prefer to do that, is that port area gonna be okay? i still get stumped with round ports.
Old 05-10-2016, 04:47 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
areo ports are WAY more efficient than standard ports, so if thats what you going to go with, you will be alright with the twins but if our using standard pvc, go with a 6'
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 05-10-2016, 05:11 PM
Ryan1126's Avatar
0/11 sssss9178
yeah just standard PVC. so the 6" will work just fine?
Old 05-10-2016, 06:00 PM
jeffdachef's Avatar
0/11 ssssss440
dont think you need that much port area man.
Old 05-10-2016, 08:25 PM
Ryan1126's Avatar
0/11 sssss9178
i had the exact same design but it was [email protected] with a single 6" at 24" and it sounded bitchin. im only redesigning because im stepping down to 8's and slightly altering the box so i have my space to recline my seat back.
Old 05-10-2016, 08:40 PM
I doubt you will notice any difference between the two designs. You'd notice a much bigger difference by moving the enclosure around in the car a bit.
Old 05-10-2016, 08:43 PM
Ryan1126's Avatar
0/11 sssss9178
so stick with the original 6" port?
Old 05-11-2016, 10:42 AM
The_Dealer's Avatar
0/11 ssssss212
That box is kinda big for those with that much power. Here's what I've had good luck with.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 05-11-2016, 12:30 PM
Ryan1126's Avatar
0/11 sssss9178
well i designed it this way for a reason so tat the top of my seat pinches the box against the back wall.
Old 05-11-2016, 12:45 PM
The_Dealer's Avatar
0/11 ssssss212
Could you go narrower(width) ? If so, I'd shoot for 1.5-1.6 cuft. with a 4" aero. The port area will look low in Torres but it will be fine, I ran a pair of hds208's in [email protected](on 1600w) with a single 4" and didn't have any port noise or any other issues. When I first picked mine up, the box(borrowed) I was using was [email protected] with 15.5sqin port per cube. It was way too big for them and they couldn't even handle but 800-900w rms(for the pair) .
4th order design tweak, how would this affect design/output/response? Benny33 General Car Audio Discussion & Questions 7 07-25-2014 07:52 AM
WTT six stickers for 4th order bp design [need design] Coast2Coast Car Audio Trader (WTT) 6 11-05-2013 11:41 PM
aero port box design help. willing to pay for working design Robertr Enclosure Discussion & Design Construction Help 2 04-20-2013 05:01 PM
help with design 20Hz_And_Below General Car Audio Discussion & Questions 3 01-11-2011 11:00 AM
