Opions please. Subaru ski pass. 4Th vs Ported - Car Audio Classifieds!
Old 05-11-2016, 11:24 AM
Mecp_advanced's Avatar
0/11 sssssss73
Default Opions please. Subaru ski pass. 4Th vs Ported
I have a 2002 Subaru Legacy gt sedan. The rear seats do not fold down. I'm going to begin a new box build soon. I want some opinons from those who have, Either personally heard or built themselves what i'm going for. Option 1. Should I go with a 4th order through the ski hole. Option 2. Aim forward in a ported scenario, Sealed off around the back side of the box, With some undecided amount of inches of clearance to the ski hole? It seemed to work well for meade in his lexus. My worries are i will not be able get enough sound or energy through with option 2. So I'm leaning towards 4Th order. Loudness is not really a factor to me. I just want the bass out of my trunk. Last 3 months, Been running a custom psi 12 on a Taramps HD1600. Just got rid of that. I'm currently bumping 2 older jbl 12's on a Zapco z50c2 2ohm mono LOL. Subs used in this build will be 2-4 of these older jbl cs12's. Or a ct sound strato 18. Power will Be a rockford fosgate 500a2 or 800a2. I'm trying to use equipment i already own and have around. So please no buy or get these subs instead. I will swap in bigger woofers and more power down the line. I have 6.2 cubes before displacement on tap. Can use spare tire well for more. Box will be built in trunk.
Old 05-29-2016, 08:03 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
If you do ported, do it firing rear. Firing forward sealed off like that is basically going to be a series 6th order.
Old 05-29-2016, 08:04 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
And is that bill hicks?
Help with 4th order band pass blow through 2 sundown x 10's rev 1 ROB-DAWG Enclosure Discussion & Design Construction Help 0 12-23-2015 12:28 AM
ski pass sub options matt02101988 General Car Audio Discussion & Questions 3 02-22-2013 02:11 PM
4th order band pass Jtasaro Miscellaneous Build Logs 0 05-18-2012 09:51 AM
look for advice/opions for mids slowpoke General Car Audio Discussion & Questions 8 10-12-2011 10:07 PM
SA 15 4th order ski hole ? treylittlefield Enclosure Discussion & Design Construction Help 12 02-24-2011 09:32 PM
