Enclosure tuning help - Car Audio Classifieds!
Old 05-26-2016, 01:59 AM
0/11 ssssss201
Default Enclosure tuning help
I have an enclosure designed a little while back and am now getting around to building. It was designed with 1/2 birch ply in mind but now the local places aren't stocking that too often, instead they have 3/4. Would someone be willing to look at my design and let me know what difference will be made if I use 3/4 for my design vs 1/2? If it's not going to be ideal I will just go the hour away to get the 1/2.
Refs: Mitch86, talon, kramer_212, kushy_dreams, ctmaudi, pro-rabbit
Old 05-26-2016, 04:31 AM
Unless the enclosure needs to fit in a tight spot, there's no disadvantage to using thicker material. To retain the same internal volume, just add 0.5" to each external dimension. If the enclosure (using 0.5" thick material) was going to be 20"x25.5"x14.5" for example, the new dimensions would be 20.5"x26"x15".
The Following 2 Users Say Thank You to SPLEclipse For This Useful Post:
Chris McNeeley (05-26-2016), MANTI5 (05-26-2016)
Correct tuning for Sundown sub enclosure? MarkAm General Car Audio Discussion & Questions 9 02-24-2014 01:13 AM
help tuning enclosure Turn it up Enclosure Discussion & Design Construction Help 6 07-16-2013 02:45 PM
Sundown Z V.2 15 Enclosure. Volume & Tuning 528hz (Sundown Audio) 6 10-30-2011 08:29 PM
tuning enclosure in reference with resonant frequency hughesc9393 General Car Audio Discussion & Questions 30 07-20-2011 08:32 PM
enclosure tuning help. Violence* Enclosure Discussion & Design Construction Help 29 12-08-2010 08:32 PM
