Volume of octagon? - Car Audio Classifieds!
Old 05-29-2016, 12:14 AM
doug118's Avatar
0/11 sssss4674
Default Volume of octagon?
Can someone tell me the outer dimensions needed to get a 1.7-1.8 cube sealed octagon enclosure? I want to see how much more space 4 of them would take up compared to a single common sealed chamber
Old 05-29-2016, 01:08 AM
0/11 sssss1070
http://lmgtfy.com/?q=volume+of+a+octogonal+prism
Old 05-29-2016, 01:11 AM
Souldrop's Avatar
0/11 sssss1270
Max dimensions would help in designing each octo to capitalize on space, but assuming a regular octagon with constant depth.
To get you in the ballpark it will be
Vol of each octagon =4*length of side*("diameter" of octagon)*depth
the diameter will be the distance form the midpoint of one side to the midpoint of the side directly opposite. This version for the volume should make it a tad easier to play around with the numbers to fit your dimensions
Assuming I did the basic maths right. Maybe someone else can check or I can check tomorrow after I catch up on sleep. Also keep in mind you still have to worry about thickness of the wood.
2016 Scion iM
- Bone stock for now
Old 05-29-2016, 08:29 AM
doug118's Avatar
0/11 sssss4674
Thanks. That was my issue was the thickness of the wood. I need to have an outer dimension of 16", just barely large enough for the subwoofer. Just don't know what dimension to cut each side nor the depth
Edit: I got the outer dimensions. Sometimes you just need to ask questions out loud and you'll figure it out.
Edit 2: I just did the volume of a cylinder, used 7.25 for a radius and found my depth. Not sure how much the volume in the corners will add up to but I'm going to guess it will be negligible
Old 05-29-2016, 05:18 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
You can find a surface area calculator and multiply the surface area by how long the octo is /1728.
Octagon shaped Transmission Line for SA8v2 Miles Build Logs 22 01-29-2014 08:15 PM
port volume? ?? noknok General Car Audio Discussion & Questions 39 09-24-2013 11:16 AM
How to get more volume SPLpizzaguy General Car Audio Discussion & Questions 5 03-19-2011 09:32 AM
Volume going down by it self? davidrforbus General Car Audio Discussion & Questions 21 06-02-2010 04:14 PM
Must keep volume down ..??? Bushj311 General Car Audio Discussion & Questions 15 01-08-2010 07:48 PM
