NSv3 15 help - Car Audio Classifieds!
Old 06-13-2016, 01:30 PM
0/11 ssssssss6
Default NSv3 15 help
Single sub back of a 06 Jetta need box designs. I am struggling and overwhelmed! SPL based low end is what I am shooting for I have about 33x33x14.5. If I have to do cutting I will to squeeze that massive cutout diameter for it. Sealed, slot ported, aero ported, cubes, I am lost with this box lol. BC3500 @ 1-ohm. Help me out guys. suggest people too I will pay!
Old 06-13-2016, 02:31 PM
dugjt88's Avatar
0/11 ssssss689
The trunk opening is going to be the bottleneck. I have a mkv wolfsburg and know all about that pita trunk opening you're gonna need most of that trunk space for the box (i was able to fit about 5-5.5cuft gross without building inside of the trunk). I'd suggest designing ported with sub and port forward and seal it from the trunk. You will also need to seal up those gaping holes under the rear parcel shelf (Will want those done either way trust me).
Old 06-13-2016, 07:53 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
You really don't have the room for that 15. Subs overall diameter is 15.5 so sub up is all you can fit with a normal box. And really not even that since the mounting depth is like 13" on those subs. You could make it work sub forward but you'd have to do some work on the baffle.
Old 06-15-2016, 12:12 PM
0/11 ssssssss6
That's about the same size as my old box was and luckily it slid in the trunk it was easy
Sent from my SM-G935V using Tapatalk
Old 06-15-2016, 01:17 PM
dugjt88's Avatar
0/11 ssssss689
Yeah mine had no problem going in or out. But i think much bigger is going to be no bueno. You can definitely fit a 15 (actual 2 will fit) in there building the box inside the trunk, and angling the baffle, but like mentioned earlier the mounting depth on that thing is pretty big.
Old 06-15-2016, 01:35 PM
0/11 ssssssss6
What kind of work exactly lol
Old 06-15-2016, 01:37 PM
0/11 ssssssss6
Big baffle recessed from the cabin and mount that big boy in. Sealed off and possibly cutting
NSv3 15 help Bwdzxc (Sundown Audio) 2 06-13-2016 02:03 PM
4 nsv3 18s massivespl Car Audio Videos 4 03-06-2016 11:01 PM
nsv3 12" TheLow Wanting to Buy (WTB) 0 08-12-2015 06:50 PM
Nsv3 availability chevy454 (Sundown Audio) 7 03-26-2015 10:22 PM
nsv3 Bassballer150 (Sundown Audio) 13 04-18-2013 05:49 PM
