Enclosure ? (playing around on sketchup) - Car Audio Classifieds!
Old 11-29-2009, 01:03 AM
0/11 ssssss480
Default Enclosure ? (playing around on sketchup)
ok just playing around on sketchup, this is a box going in my car which is subs up port back for 6 12s. It's really a rough idea oh how the box will be built just for illustration. The question is as you can see the top row of speakers is kind of over the port beginning, i was wondering would there be a loading problem into the port for the top row..........
(sorry i'm a beginner at sketchup so no jokes )
The Rebuild
Powerbass Xta5000.1 (check)
4 DB Drive PLW12s (check)
Box 9.1cuft @ 29hz (check)
3 dekas (2 of 3)
alternator
alpine cda 9886 (check)
10 seleniums (check)
Punch 850.2 (check)
Old 11-29-2009, 01:10 AM
it'll be fine I would put the 3 over the port opening closer to the other 3 though
Old 11-29-2009, 01:30 AM
0/11 ssssss480
ok coo, stuck between this setup and 8 10s
The Rebuild
3 dekas (2 of 3)
alternator
Punch 850.2 (check)
Old 11-29-2009, 01:32 AM
it'll help load the box and not the port so less strain on subs and more efficient
kingmade08's Avatar
Awaiting Confirmation
0/11 sssss1067
wenn,wen i build my box,how much will u charge for a design?
Old 11-29-2009, 01:34 AM
0/11 ssssss480
referring to the 10s?
The Rebuild
3 dekas (2 of 3)
alternator
Punch 850.2 (check)
Playing around with a few designs... get_low Enclosure Discussion & Design Construction Help 5 11-22-2009 09:38 PM
Google Sketchup help Patrick Simmons Enclosure Discussion & Design Construction Help 5 07-16-2009 01:40 PM
How to: Draw a box using Google Sketchup SPY Tutorials & Quick References 12 01-17-2009 01:23 PM
Sketchup Tutorial caps Tutorials & Quick References 2 01-17-2009 01:03 PM
