running under box reccomendations, should I tune different to help accomidate? - Car Audio Classifieds!
Old 06-26-2016, 08:30 PM
williamhung's Avatar
0/11 ssssss536
Default running under box reccomendations, should I tune different to help accomidate?
Going to try and shoehorn a zv4-18 in the trunk of an '06 honda accord. Couldn't pass up the great deal on a yard sale zv4-18...I knew we were biting off more than we could chew lol, but we gave into temptation so here we are. I very much doubt we can get 7 cubes out of it so if im stuck with around 5.5-6 cubes whats the best tune i should go with to help accomidate the smaller box? User listens to mostly rap so I want it somewhere in the 32-33 range. Is there any other things I need to consider? Port size? Power? Think power will be 3200 watts via two cab-1600.1's strapped at 2ohms. Thanks for any help fellas!
2 Stereo Integrity HT-15's
1 Stereo Integrity HST-15
Old 06-26-2016, 08:57 PM
mega fatty
0/11 sssss6008
You may be able to find 1cf if you tune around 35hz
Or you could go slightly smaller on port
I would do 1 8" aero port and see where it gets you
You could always drop down to a single 6" to lower tuning if you made something interchangeable
Old 06-26-2016, 10:26 PM
0/11 ssssss536
Thanks, I almost forgot that Jacob had already told me that 35hz was his prefered tuning for the zv4 since it digs down low anyway and the rise in tuning helps hit the high notes better....also happen to have a section of 8" pvc i could use...but i may have to resort to running 2 slot ports due to design of the trunk. But ideally the aeroport will give me more room....this is gunna be a b**** getting to fit lol.
Old 06-26-2016, 10:38 PM
0/11 ssssss536
Old 06-26-2016, 10:51 PM
0/11 ssssss536
Haven't done a trunk build since I was a teenager....any special recommendations I should consider? I would love to seal the truck off and have the sub and port blow out the fold down rear seats...but the opening isn't 18" tall...I believe its around 16" or so...I wonder if i could angle the sub in a way to make it work....maybe kinda like the jl audio box...(not that its angled but like that in a way that the port blows into the opening above the sub...but i would have 2 ports blow in from the sides) to be able to seal off the trunk and have both port and sub blow thru the rear seat opening....
what should i tune my box to macandcheese General Car Audio Discussion & Questions 5 04-13-2013 07:59 AM
SQ box reccomendations for 1 15" RD alpha v.3 cato3 Enclosure Discussion & Design Construction Help 0 02-10-2010 10:51 AM
What should I tune my box to? gbo559 General Car Audio Discussion & Questions 6 08-18-2009 09:24 AM
what should i tune my box at? vicon4z General Car Audio Discussion & Questions 8 07-27-2009 01:44 AM
what should i tune my box to? jeres313 Enclosure Discussion & Design Construction Help 27 03-04-2009 11:24 AM
