port area, freind or foe? - Car Audio Classifieds!
Old 07-04-2016, 05:35 AM
williamhung's Avatar
0/11 ssssss536
Default port area, freind or foe?
So, as ive gone from slot to aero ports iv'e noticed that the less port area the more the sub comes close to bottoming out. You get more movement with small port area of an aero but at lower power. Both really sound the same but the smaller port area of an aero sems to put my sub in jepordy of bottoming out and blowing. My subs are very soft low fs stereo integrity home theater subs. I never had a problem with them coming close to bottoming out in my old slot box that was 57sq in of port area...now same size box but with a 6" aero, im bottoming out like a mother****er! Cant really tell a big difference in sound between the two. Other then the coil smacking the back plate. Is this because they are soft and the less port area has exploited that or is it better to run large port area when over powering subs?
2 Stereo Integrity HT-15's
1 Stereo Integrity HST-15
Old 07-04-2016, 05:45 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
What's the tuning on both?
Old 07-04-2016, 05:50 AM
0/11 ssssss536
Tuning is 32hz on the aero, and 34hz on the slot as far as my calculations. Just crazy to hear my subs hit the back plate when i could throw tons of power (1600 watts each) to them with a slot and all i had to worry about was coil stink.
The Following User Says Thank You to williamhung For This Useful Post:
soBASED (10-06-2016)
Old 07-04-2016, 05:55 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Are the ports both the same distance from the loading wall?
0/11 ssssss536
Previous slot box was too much port area @57 sq in. But man i never imagined these subs bottoming out the way they are now
Old 07-04-2016, 05:57 AM
0/11 ssssss536
Excactly the same...built the.box to be the same distance from the rear of my tahoe as i wanted to keep the same cargo area...thats why i went with aero's so i could add a third sub within the same space as the 2 i have now. But have yet to add the 3rd sub.
Old 07-04-2016, 06:06 AM
0/11 ssssss536
The box is a three subs up, port back box with seperate chambers with 6" aeros in each chamber....i seperated the chambers because i was going to run my hst-15 with my two ht-15's. The hst 15 getting one amp and the ht-15's getting the other....but blew one ht-15 before i could finish...and now i blew the hst 15...
Old 07-04-2016, 07:41 AM
doug118's Avatar
0/11 sssss4674
Did I miss where you said what size the boxes are and what size the slot port is?
needing advise for my new build. cubic feet, port area, and sub an port orientation nick_215s Enclosure Discussion & Design Construction Help 3 01-25-2016 03:01 AM
octo port and port area williamhung Enclosure Discussion & Design Construction Help 2 08-12-2015 10:11 AM
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 09:04 PM
Port area vs. Port length TaylorFade General Car Audio Discussion & Questions 3 10-20-2011 09:52 PM
