what cab for mercedes ml 430 - Car Audio Classifieds!
Old 11-30-2009, 12:59 PM
0/11 ssssss196
Default what cab for mercedes ml 430
as the title says i have a Mercedes ml year 2000 what sort of cab or cabs would work best,i have about 11.059 ft3 before displacement will be using 4x12" or 2x15" subs i have 2500 rms 1ohm. im not chasing numbers but would still like to be doing 140+ db.i like really low tunes systems hope you guys can give some ideas i know my car peaks very low.thanks fo taking the time.
Old 11-30-2009, 02:20 PM
98AckCL23's Avatar
0/11 sssss9929
You should be able to get into the mid 40s with 2 12s and 2500w... Even in a nice simple L ported box... With my 10s and a Sundown 1500D, I'm almost into the 40s at 32hz on a burp.
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 11-30-2009, 02:22 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
you should be doing 140+ EASY.
I did a 140 in a trunk off 900 rms and 1 15".
that was at 42hz tho.
Old 11-30-2009, 04:42 PM
0/11 ssssss196
thanks for reply's so far guys i know in different cars it can be done but im talking about a Mercedes ml430 lots of cabin space to fill.i dont want a high tuned system i want low bass but be able to still play high enough.i have tried and tested high tuned cabs in my car and i dont like them,yes they gave me the output . i use my car daily not to fussed about using most of boot area. any ml installs about that i can look at?all cab idea's thanked in advance
Old 11-30-2009, 04:50 PM
0/11 ssssss922
Here's a Link with my old ML to give you some Box Ideas. Here's My Rides
Old 11-30-2009, 04:51 PM
0/11 sssss3181
Feedback Score: 23 reviews
i am doing about 140 on 1200W and 2 12"s @ 44 hz
Old 11-30-2009, 07:24 PM
0/11 ssssss196
thanks for the info duramaxxed,andrew if you look you will see others have said the same as you. i can do that easy high tuned dont want high tuned system i want a low sql system i need some idea's not what your achieving in your cars.this is a car that plays music not a burp mobile,thanks so far guys any more ml installs about? or any type of cabinets that i could think of trying.
Old 11-30-2009, 08:02 PM
98AckCL23's Avatar
0/11 sssss9929
Originally Posted by 98AckCL23 View Post
Even in a nice simple L ported box... With my 2 10s and a Sundown 1500D, I'm almost into the 40s at 32hz on a burp.
Tuned at 30.125hz, btw...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 11-30-2009, 08:41 PM
0/11 ssssss196
Tuned at 30.125hz is that for a cab in a ml or is that just a box freq you are sudgesting
Old 11-30-2009, 08:50 PM
98AckCL23's Avatar
0/11 sssss9929
That's my box tuning in my Acura CL... Mine's just a simple L-port setup, and is doing some decent numbers down low, which if you ask me, is the only place that matters...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Mercedes benz factory radio model cm 1330 videodorome Head Units, Processors & EQs 1 11-11-2008 10:40 PM
Rock Crawler from Legendary Motor Company (based on Mercedes-Benz GLK) Patrick Simmons General Automotive Chat 3 11-10-2008 11:32 PM
2009 Mercedes-Benz CLK Patrick Simmons General Automotive Chat 3 11-07-2008 10:29 PM
2010 Mercedes-Benz S 400 BlueHYBRID Patrick Simmons General Automotive Chat 4 09-22-2008 04:14 PM
Vorsteiner Black Widow (based on Mercedes-Benz CLK63 AMG) Patrick Simmons General Automotive Chat 3 09-19-2008 03:07 PM
