Using Wood Glue/ Silicone - Car Audio Classifieds!
Old 09-22-2016, 02:28 PM
tntahoe's Avatar
0/11 sssss1196
Default Using Wood Glue/ Silicone
I was just curious if you all use wood glue when attaching your wood together. I use it but I was moreso wondering how are you all modifying your box after everything is glued together. Are you not glueing one specific piece, lets say you glue every piece together except maybe the front baffle just in case you want to change up your sub configuration or port or something else. I hope I am making sense here. I was thinking of just using silicone on my front baffle to make it airtight and if I wanted to change the amount of subs or new port I could just unscrew it and remove the silicone. In my experience it is not that simple to remove a piece once that glue sets up. Please chime in and let me know your thoughts.
Old 09-22-2016, 03:34 PM
doug118's Avatar
0/11 sssss4674
use this
Frost King E/O 3/4 in. x 7/16 in. x 10 ft. Black High-Density Rubber Foam Weatherstrip Tape-R734H - The Home Depot
Old 09-22-2016, 05:16 PM
0/11 sssssss46
Usually I tailor the box to the subs specifications but if you want to design for using the same box for different subs then I would use flanges for the sub and or ports on the front or top of the box. An example would be to make the cut out for an 18" sub and then bolt a cover over it that has a cut out of a 15" sub. Then all you would need to do is use weather stripping to seal the new cover onto the box. I would also recommend using t nuts and regular bolts instead of coarse thread wood screws for the new covers or flanges to prevent premature wear and tear of the box. Now you can just replace the flanges as you see fit.
Old 09-23-2016, 09:43 AM
tntahoe's Avatar
0/11 sssss1196
I think I will give this a try.
Old 09-27-2016, 11:38 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Not very often you come across someone that uses the same enclosure over and over again. What happens if it's nice looking aka, painted, carpeted, etc.
Hence why a new enclosure needs to be built.
iirc, TaylorFade has an adjustable enclosure for testing purposes. He's showed pics of it. Basically, a slide in/out type. That way, you can shrink cf ft or increase it.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
What kind of epoxy or glue should i use for gluing plastic to wood? djm4rshm2llow General Car Audio Discussion & Questions 5 03-13-2013 09:21 PM
Construction Adhesive or Wood Glue?? Winter_C Enclosure Discussion & Design Construction Help 13 07-30-2012 08:41 PM
Gorilla glue vs Gorilla Wood glue KNOTDUDE Tutorials & Quick References 22 05-10-2012 02:50 PM
Liquid Silicone - Where u get urs? upzaw2000 Off Topic Chat 13 07-21-2010 10:42 AM
