help - Car Audio Classifieds!
Old 10-07-2016, 12:53 AM
0/11 sssssss20
Default help
I need help please one subwoofer box 4 15" dc lvl 3 2 dc2.0k amplifiers each amplifier for 2 subwoofer each subwoofer supports 900w rms Electrical Q Value (Qes): 0.706Mechanical Q Value (Qms): 8.18Total Speaker Q Value (Qts): .65Free Air Resonance (Fs): 30.9 HzEquivalent Compliance (Vas): 84.88 litersOne-Way, Linear Excursion (Xmax): 23 mmEfficiency (Ref SPL @ 1W): 87.3 dB (90.8dB @ 2.83V)Effective Piston Area (Sd): 823 cm²DC Resistance (Re): 3.6 ohmNominal Impedance (Znom): Dual 4 ohmForce Factor (Bl): 17.2Mechanical Compliance (Cms): .09 mm/NMechanical Mass (Mms): 295 gVoice Coil Inductance (Le): 3.5 mHSuggested Sealed Enclosure: 2.00 ft³Suggested Ported Enclose: 3.00 ft³
Sent from my LGMS631 using Tapatalk
Old 10-07-2016, 04:48 AM
Would you like to know what size or type of enclosure? Do you need someone to build it for you? Do you need a cut sheet for materials?
Old 10-07-2016, 08:19 AM
0/11 sssssss20
i want to make a box for a ford explorer 4 15s facing up, port back.
max 41 wide 38 deep 26 high
Old 10-07-2016, 08:24 AM
0/11 sssssss20
Old 10-07-2016, 08:29 AM
0/11 sssssss20
You think this is too big
Old 10-07-2016, 08:46 AM
0/11 sssss1117
Big enough, but idk the port specs, also you can change that to what your listening style is
Old 10-07-2016, 08:50 AM
0/11 sssssss20
I want to compete BASS BOXING is a type of SPL competition (sound pressure level) using full range music as the main judging
criteria. Bass Boxing pits several competitors against each other until one competitor prevails as “Champion”. It’s a true
test of how a system performs in every day applications.
The Qualifying Round is a 30 second round. Competitors are allowed to use any approved, commercially available
music. All competitors compete in the qualifying round and the top two (2) contenders with the highest average SPL
score in each Bass Boxing Division will move on to the final rounds.
Final Rounds - The top two competitors in each Division will go against each other in an all out, full range musical SPL
competition for three final rounds. In these rounds, competitors may once again choose any approved commercially
available music. Each Round has specific criteria; please read the General Bass Boxing Rules on the next page for
details. These rounds will also last 30 seconds each and the Judges will register the highest average SPL score during
that timeframe.
In all Bass Boxing competition rounds, the full range of music (not just bass) must be heard cleanly and clearly by
everyone (outside sound), including judges and spectators, so the goal is to build a system that sounds as loud and
good outside as it does inside! cant you help me whit te port specs
Old 10-07-2016, 08:54 AM
0/11 sssssss20
dc like small box big port ist box that true??
Old 10-07-2016, 04:49 PM
0/11 sssss1117
Nk
Well let me get. The basic info.
What subs you have?
How many and size?
What amp you have and your final ohm load?
This will help determine how large of an box you will need and port volume. And obviously since this will be mainly musical/spl. Tuning will be in the high like 40hz, almost 98 percent of commerical music are above 45hz.
Old 10-07-2016, 04:56 PM
0/11 sssssss20
4 15" dc lvl 3 2 dc2.0k amplifiers each amplifier for 2 subwoofer each subwoofer supports 900w rms final 1 Ω1000w each subwoofer ford explorer 4 15s facing up, port back
