Aeroport help - Car Audio Classifieds!
Old 10-11-2016, 05:52 PM
soze1's Avatar
0/11 ssssss208
Default Aeroport help
How close to the back wall of the box can I have the end of the port??
set up is in the trunk of a 2015 civic
Rockford T2S1-13
Rockford T2500-1BDcp
I want to fire sub and port forward and seal it off. Planning on using an 8" port tuned to 33 but the length is becoming a problem. I also have a 6" Precision Port but I'm not sure that will be sufficient port area.
Old 10-11-2016, 06:33 PM
Micksh's Avatar
0/11 sssss2596
We usually go no less than the width of the port to the back of the box. But honestly, the 6" should be fine. We do two 15s with two 6" aeros all the time and have built many 150+ legal setups using that configuration. Especially in a musical set up like that.
My Youtube page
Astro build log link
Old 10-11-2016, 07:06 PM
soze1's Avatar
0/11 ssssss208
Thanks.
I think what I am going to do is use the 6" but make it removable. 6" for daily and a couple different length 8" if it ever sees a meter.
Old 10-12-2016, 10:41 AM
doug118's Avatar
0/11 sssss4674
My port was half the diameter away from the back wall and did a 155 "legal"
Old 10-12-2016, 01:53 PM
Micksh's Avatar
0/11 sssss2596
Typically that's what they recommend, half the diameter. It can affect tuning if it's too close though.
Sent from my SM-G925V using Tapatalk
My Youtube page
Old 10-12-2016, 05:24 PM
soze1's Avatar
0/11 ssssss208
that's good to hear, if i can go 1/2 the diameter it makes things much more flexible.
aeroport help hdman87 Enclosure Discussion & Design Construction Help 3 01-12-2013 08:13 PM
aeroport tuning? AQ28576 General Car Audio Discussion & Questions 12 03-03-2012 05:12 PM
Aeroport help for nsv2 dbass Enclosure Discussion & Design Construction Help 14 02-19-2012 07:52 PM
45's in an aeroport focusedfornow Enclosure Discussion & Design Construction Help 4 09-22-2011 12:07 PM
Aeroport Help Please?!? Pieper Enclosure Discussion & Design Construction Help 6 04-18-2010 05:04 PM
