Need help with an easy box - Car Audio Classifieds!
Old 10-31-2016, 11:17 AM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
Default Need help with an easy box
Got a pair of DD 9512f D1's that ill be running on a pair of Rockford T1500-1bdCP's.
I have a 10" ID x 26" long aeroport, what would be a good box size for the 9512's on 1500rms each with this port to bring my tuning down to something reasonable? Shooting for 34hz.
Old 10-31-2016, 12:15 PM
0/11 ssssss275
5.5 cubic feet I believe
Old 10-31-2016, 04:04 PM
Raptor660's Avatar
0/11 sssss5243
5.5cu ft seems too big for a pair of 12's
Old 10-31-2016, 06:31 PM
0/11 ssssss275
He asked to utilize that port and tuning. DD finds 2.75 cubes acceptable for a single 12
Old 10-31-2016, 07:56 PM
Raptor660's Avatar
0/11 sssss5243
Ok cool.. thanks. Do u think that box will work well with that much port area?
Old 11-01-2016, 03:26 PM
Raptor660's Avatar
0/11 sssss5243
Anyobe else? Is 79sq inches of port area to much for a pair of DD 9512's? Can this work well?
Sent from my SM-G900P using Tapatalk
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 11-01-2016, 03:41 PM
0/11 sssss3526
Ive "heard" that DDs do well up to 20^2. I dont think that 79 is too much based on what ive seen and heard. No firsthand experience however
79 is only 14.3^2
The Following User Says Thank You to kr-15 For This Useful Post:
Raptor660 (11-01-2016)
Old 11-01-2016, 04:49 PM
The_Dealer's Avatar
0/11 ssssss212
Pay less attention to the port per cube, and look more at what the vent velocity will be with __ port dimensions. I like to stay between 24-28 m/s after I factor in the ssf/lpf. I did a box for 4 sa-12 that only had 13sqin port per cube, last week I did one for a custom 10" that had 23sqin per cube. The amount of Port per cube isn't even relevant to anything, the numbers don't matter, the vent velocity is what decides if you have issues. Too low and the subs perform like shit, and too high and you'll get port noise and the subs will still perform like shit.
Edit: I'd stay between 2.5-2.65cuft net per sub and they get loud.
Sent from my SM-G920T using Tapatalk
Old 11-01-2016, 09:39 PM
Raptor660's Avatar
0/11 sssss5243
Thanks.. wanna help with a box design? Lol
Easy box for treo ssx 28hz? graham Enclosure Discussion & Design Construction Help 9 10-20-2015 02:36 PM
Easy box build iamthewalrus Box Requests 6 09-18-2012 02:08 PM
Maybe an easy question DeltaOn4's General Car Audio Discussion & Questions 9 05-31-2010 06:54 PM
As easy as 1-2-3? F3M4 Enclosure Discussion & Design Construction Help 7 12-15-2009 06:33 PM
Wiring Help... easy outside box config thingy.... upzaw2000 General Car Audio Discussion & Questions 13 01-06-2009 05:33 PM
