Sound Dampening inside box - Car Audio Classifieds!
Old 11-02-2016, 08:45 AM
0/11 ssssssss9
Default Sound Dampening inside box
anybody ever dynamatted the inside of a box?
Old 11-02-2016, 10:39 AM
Red Light Ear Rapist
0/11 sssss1397
waste of time and money, if you feel frisky resin that b*tch
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 11-02-2016, 01:29 PM
0/11 sssssss33
For sure. Resin and sand that thing with 200 grit. Will fill up those pores in the wood and lower your box rise (very slightly I might add).
Old 11-02-2016, 01:50 PM
0/11 ssss31258
I once bought a box 2nd hand which a local shop built
Every panel was double layer 3/4" MDF with original dynamat in the middle.
if you want a box which wont resonate, use MDF.. if you want it even deader? deaden it.
but don't use Plywood and then deadener
Old 11-28-2016, 08:21 PM
0/11 sssss1122
Feedback Score: 23 reviews
Why wouldn't you use plywood then deadener?
Old 12-17-2016, 11:30 AM
Old thread.... but home theater guys deaden their boxes all the time. In a car you won't tell as much.
Old 12-17-2016, 11:49 AM
0/11 ssss31258
might as well just use MDF instead
Old 12-17-2016, 11:54 AM
So Low's Avatar
0/11 sssss1258
If you are using mdf you would be hard pressed to get panel resonance in a subwoofer box, assuming you have fastened the panels correctly. Very uniform density, ideal for acoustics. With ply you may have resonances in higher frequencies than a subwoofer will play, due to the density differences in the wood, and proper bracing usually does enough to eliminate them. But for a subwoofer, panel flex should be your only concern, not panel resonances.
Old 12-18-2016, 08:10 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Dynamating inside a sub enclosure? Nah, not necessary.
Resin the insides of a sub enclosure? Sure. Some people have. Others don't. Takes time to do tho...in between drying and applying. So what's the difference between a reg ported enclosure with nothing inside vs one that has resin inside? Perhaps a more smoother response? Or just plain making it as solid as a rock in hopes to not resonate?
A properly built enclosure with plentiful of bracing should do the trick.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 12-18-2016, 09:53 AM
So Low's Avatar
0/11 sssss1258
Assuming the resin dries to a smooth surface, air will see less resistance fleeing over it. In the port, the more resistance the air sees the "heavier" the air spring is, so a resined port will tune it higher. But not by much.
The real benefit of resin is to create a one-piece shell on the inside of the box to seal it well
The Following User Says Thank You to So Low For This Useful Post:
SPLEclipse (12-18-2016)
sound deadening/dampening?? Inferno3436 Sound Deadening & Fabrication 4 03-27-2014 06:48 PM
Wire and sound dampening Joemama General Car Audio Discussion & Questions 41 03-27-2013 12:44 PM
sound dampening burd337 General Car Audio Discussion & Questions 8 02-17-2013 10:17 PM
Can painting the inside of a sub box hurt the sound or help it? Mnorwood01 General Car Audio Discussion & Questions 17 12-02-2012 12:51 PM
sound dampening sale Xtremelegend General Car Audio Discussion & Questions 3 11-07-2012 11:30 PM
