3 jl 10w7 - Car Audio Classifieds!
Old 12-10-2009, 09:02 AM
0/11 sssss8594
Feedback Score: 55 reviews
Default 3 jl 10w7
im going to add 3 10w7's to my system...ive got 2 cvx's in a big sealed box (36x11.75x16)that im getting rid of...i have NO MORE than 11.75" H and 36" L...the depth i can add to though...to make 3 w7's fit correctly with the right amount of cu.ft (1.25 sealed), i have to add to the depth significantly...i jus need to double check to make sure my math was correct and that im not missing anything...i found that i can use 3/4" MDF all the way around with a 1-1.5" baffle...the OUTER dimensions being 36"L x 11.75" H x 22" D...ive also got 2 3/4" MDF dividers so the box has 3 separate chambers...each chamber being 11.75" H x 12" W x 22" D...did i properly account for the 2 dividers or will there not be enough room in the length??...the way i looked at it is that ive got 34.5" inside...with the 2 3/4" dividers, ive got 33"...the mounting diameter for the w7's is 10.5"...giving me 1.5" to use as free space to just divide up the subs...is this correct or am i missing something
Old 12-10-2009, 12:24 PM
0/11 ssssss125
yes your math is right.
Old 12-10-2009, 03:01 PM
0/11 sssss8594
ok, thanks
[SOLD]10w7 in Enclosure nismos14 10" Subwoofers 30 08-13-2009 01:29 PM
wtt 10w7 (SOLD) tc3k101 Car Audio Trader (WTT) 7 04-21-2009 03:37 PM
[SOLD]fs jl audio 10w7 tc3k101 10" Subwoofers 0 04-11-2009 08:59 PM
