(2) Fi Audio BTL 15 Neo enclosure - Car Audio Classifieds!
Old 11-28-2016, 10:31 PM
0/11 sssss1122
Feedback Score: 23 reviews
Default (2) Fi Audio BTL 15 Neo enclosure
I am building an enclosure for two 15" BTL Neo subwoofers, D1. The t/s specs from Fi are not jiving Bass Box 6. I want to double check with you all that I have a good design.
Goal: Ground pounder, musical enclosure. I have a Twisted Sounds 2.8k, love this amp. It is a solid 3.5kw amp.
Enclosure design:
  • 7 cubes net
  • tuned to 32hz
  • 120 inches of vent area (20x6")
Is the vent mach in-check with this design? Would you recommend anything different?
BTW this is a trunk build, external port through rear deck.
Old 11-28-2016, 11:52 PM
0/11 sssss1122
I came across this post on another forum that I modified.
Small's formula
dv = 39.37 (fb x Vd)^1/2
dv= minimum port diameter of vent in inches
fb= box tuning frequency in hertz
vd= cone displacement in cubic meters (one way xmax in meters times cone area in meters)
for one BTL Neo 15
xmax= .034 meters
sd= .018 meters^2
tuning= 32 hertz (per you)
dv= 39.37 (32 x .034 x .081) ^1/2
dv= 39.37 (.088128)^1/2
dv= 39.37 (.29686)
dv= 11.68737 inch diameter port per sub
dv= 107.28 square inches
for two 15's you need (2)dv. So you need 214.56 square inches of port.
Is that correct?
Old 11-29-2016, 12:39 AM
0/11 sssss1417
Tuned to 33hz with 214 sq inches of port, external port through the rear deck will extend out the window into the ozone layer.
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
Old 11-29-2016, 08:42 AM
0/11 sssss1122
That's what I'm saying
Old 12-02-2016, 06:54 PM
0/11 sssss1122
No one offered help but Fi did, quickly too.
I'll be building :
- 8 cubes
- 120 sq in port
- tune to 30-35 hz
Old 12-02-2016, 07:19 PM
0/11 sssss1417
I'll be building :
- 8 cubes
- 120 sq in port
- tune to 30-35 hz
They have recommendations on their website.
Team Scoshe
Team Sears
stealth(Today)
Old 12-02-2016, 07:43 PM
0/11 sssss1122
Yes they do
Fi BTL N3 Neo Souldrop eBay 2 11-21-2014 10:06 PM
2x DC Audio NEO Motors and Fresh Neo Recones bre2ts Speaker Accessories & Parts 10 08-30-2013 04:35 AM
[SOLD] 3 lightning audio neo motors !!!! + a top plate and a neo slug psychoacoustics Speaker Accessories & Parts 42 12-11-2012 07:42 AM
Enclosure Build for 10" LA Storm Neo bergend2 Build Logs 22 03-04-2011 06:24 PM
Enclosure help for btl Team3d Enclosure Discussion & Design Construction Help 0 04-16-2009 09:45 PM
