Box tips and tricks... - Car Audio Classifieds!
Old 12-10-2009, 09:01 PM
Prohibited Sellers/Buyers
0/11 sssss2890
Default Box tips and tricks...
Looking for box tricks and tips for the most efficient box I can build...
PVC in the corners? ( any one got photos? )
Sound Deadener inside or outside the box?
8" areo ports how?
Is slot or areo better?
Old 12-10-2009, 09:03 PM
HHR_Ed's Avatar
0/11 sssss1871
8" areo ports how?
Dont do PVC or angles in the corners unless you know what angles and positions to use.
Doing it the right way can help but is very tricky. Doing a general 45 most often will hurt rather than help.
Its a common misconception though.
Ed Lester.
YouTube
Old 12-10-2009, 09:05 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
how can you go wrong with 45's?
1999 Durango 2 Memphis Mojo 15's Audiopipe ap3k
4 Date Safe 75 ah batts Alpine hu. Lots of wangin
Old 12-10-2009, 09:12 PM
HHR_Ed's Avatar
0/11 sssss1871
Can create standing waves and pockets of high and low pressure in places you dont want them.
Ever see someone blow out cones of their woofers in multi woofer enclosures, and each time its usually the same woofer?
It happens because the box shape causes too much back pressure behind that particular woofer.
Even if you dont have enough power to blow a cone, it can still diminish performance.
But if you do it right and get the pressure to build in the proper places, then it would help performance.
Ed Lester.
YouTube
Old 12-10-2009, 10:41 PM
on1wheel01's Avatar
*SPEED RACER*
0/11 sssss1319
well whats the proper way then? I'm about to do a box build and this is new news to me(keep in mind im a novice builder)
Old 12-10-2009, 10:44 PM
the proper way is rebuild it 10-20 times to get it perfect
Can I do Hair Tricks? MaTT6387 Off Topic Chat 28 10-31-2009 08:13 PM
General tips on 1/0 gauge cutting? AuZy_AuDiO General Car Audio Discussion & Questions 24 10-17-2009 02:34 PM
Any tricks to louder sealed up? aturcotte127317 General Car Audio Discussion & Questions 49 08-05-2009 05:05 PM
Tips to stay awake 92K1500 Off Topic Chat 20 02-09-2009 04:43 AM
