Ok help with ported - Car Audio Classifieds!
Old 10-27-2008, 11:34 AM
worstenemy453's Avatar
Veteran Member
0/11 sssss4401
Default Ok help with ported
I am planning on getting 2 AQ SDC2.5 15"s and i wanted to do ported but i believe they are around 4 cubic ft ported a piece. Is there any way to change the port size so i can run them in a much smaller box like around 4 cubic feet for the pair and just have a bigger port or something or am i just going to have to do sealed. Sealed isnt a problem but i know it wont get as loud.
Old 10-27-2008, 11:40 AM
forceww's Avatar
0/11 sssss3264
you could use aero ports and keep the internal volume smaller and still get the port area needed for your application. If you used external ports it might help you even get louder than planned
ANOTHER New System
Team SBC-Team CACO-Team Lethal Beatz
plenty of refs just ask
Old 10-27-2008, 12:21 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
You would still need to stay roughly at box requirement size wise, just use the aero's to ge the appropriate tune.
My Car, My Ears.
Old 10-27-2008, 01:55 PM
forceww's Avatar
0/11 sssss3264
it would help a little bein able to have somewhat of a smaller box. However i just read over the first post again and saw tat they require 4 cu per and your wantin 4 cu for the pair? If im correct in wat I read then thats gonna be almost impossible to do without it bein purely for a burp or sumthin. So im not sure man
ANOTHER New System
Old 10-27-2008, 01:59 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Or isobarically mounted, and still then, you'll have a problem running that settup effectively.
My Car, My Ears.
Old 10-27-2008, 07:07 PM
Veteran Member
0/11 sssss4401
If its pretty much impossible then ill proly just run sealed and get some good SQL
Anyone Ever Seen A Slot Ported..... only126db General Home Audio/Video 6 12-08-2009 04:23 PM
2 15'' L7s in ported box nyckid718 15" Subwoofers 5 11-25-2008 06:55 PM
looking for a ported mwne2nks Enclosure Discussion & Design Construction Help 1 11-18-2008 08:29 AM
Recommended Ported Box for '05 RE XXX? Cheesemind Enclosure Discussion & Design Construction Help 6 11-02-2008 01:34 AM
SI MAG 12" & ported box $350 Mat J 12" Subwoofers 2 08-25-2008 09:54 AM
