aero port help - Car Audio Classifieds!
Old 12-12-2009, 10:58 AM
csu87's Avatar
Louder then him^
0/11 sssss2525
Feedback Score: 22 reviews
Default aero port help
im making a box for my 12 that i just built. im think about 2cuft after displacements but am unsure on what size aero i should use. how do you calculate the amount of port area when using aeros? would a 4" aero work or should i get a 6"?
Current 09 BMW 335xi: SQ build with Sundown and IA in progress
Retired '99 Jimmy: Highest TL 155.1 w/ 2 self made 12s and AQ3500.1
Old 12-12-2009, 11:00 AM
resko1's Avatar
<<< atomic at7000.1d
0/11 sssss2134
Feedback Score: 21 reviews
2-4" areo's. It would give you exactly 16sqin of port surface area per cu ft.
just an old fart
Old 12-12-2009, 11:01 AM
lileddie1127's Avatar
0/11 sssss1225
What 12? I use the PSP calculator. http://www.psp-inc.com/tools.html
I did a DD3512 in 3 cubes with one 6 inch aeroport and it slammed. 143.3 TL legal sealed up (not a fart box)
6th order coming soon!
Team Juggernauts
Old 12-12-2009, 11:13 AM
0/11 sssss1225
Here's a pic of the box:
http://i82.photobucket.com/albums/j2...plsetup008.jpg
Hope this help
Team Juggernauts
Old 12-12-2009, 11:26 AM
resko1's Avatar
0/11 sssss2134
That would be a PSA of 12sqin per cu ft. Im sorry, i doubt that with the windows up. I have a 3512 and my first box was 3cu and had a psa of 13.5 and i could only pull a 139 out of it. When i built the second box, still 3cu with 16.5 sqin of port, same tuning(38hz) i pulled a 144 out of it. Port surface area means a lot when it comes to sub effeciency. Too small a port and you will "load" your car too hard, which means you will have to have the windows down a little to be loud. Too much port and your sub/s will unload too fast. Use right around 15-16sqin per cu foot and you cant go wrong. For 2cu, 2-4" Areo ports are perfect!
just an old fart
Old 12-12-2009, 11:38 AM
0/11 sssss1225
You doubt that? Let me get some pics uploaded there for ya. Also, would you like to see a video of it? I can show you that as well. I'm no rookie buddy.
Team Juggernauts
Old 12-12-2009, 11:39 AM
0/11 sssss1225
OP, Sorry for the thread jacking. Resko1, pm me if you have any questions...
Team Juggernauts
Old 12-12-2009, 11:45 AM
resko1's Avatar
0/11 sssss2134
Then you must have something going on that i dont. I couldn't get past 139 with that low of PSA on 3k! and there was no way i was getting over 144 total with that sub on 3k. Maybe you did. I wasn't there, but it seems unlogical since every box i've ever built with a psa lower than 14 pcf sounded like ass with the windows up. And im no rookie either bro. Been doing this over 10 years.
Sorry OP, but i stand that 2-4" Areo's is perfect for 2cu.
just an old fart
Old 12-12-2009, 11:54 AM
0/11 sssss1225
No prob man I been doing it for 10+ yrs myself, Biggy/MRrileySS on this forum was there that day. OP, for 2 cubes I would do 2 4' aero's like Resko1 said, for 3 cubes like I proposed (depending on the sub/tuning), one 6' aero worked very well for me. You can get away with less port area with aeroports.
Team Juggernauts
Old 12-12-2009, 12:05 PM
TurboFox's Avatar
Sum Kinda Mawdified Fuord
0/11 sssss1294
Theres way more factors as to why he could have gotten louder than you were able to. Car, impedance rise, 3k watt amp being used, electrical system, box design, etc, etc...
Hell, put your setup in a crx and I guarantee it would easily be louder than either of you with the same power.
Guess what... im that kindergarden girl!!
Aero port displacement Scapelli21 General Car Audio Discussion & Questions 7 09-06-2009 08:21 AM
Aero port tuning tater Enclosure Discussion & Design Construction Help 2 05-26-2009 12:55 AM
aero port on the outside? mrboost General Car Audio Discussion & Questions 4 01-19-2009 09:59 PM
9.5 inch Aero Port Tinted Speaker Accessories & Parts 5 12-11-2008 10:39 PM
