Dose the size of your car change the final tuning - Car Audio Classifieds!
Old 01-23-2017, 03:00 PM
0/11 ssssss313
Default Dose the size of your car change the final tuning
Iv been messing with torres box tuneing calculator and I'm wondering because I have a van will that effect the final tuning.. would tuning higher or lower help get me back to the original 28hz?
Old 01-23-2017, 05:00 PM
jeffdachef's Avatar
0/11 ssssss440
with a longer vehicle, your cabin peak will be lower if you have the port firing to the rear.
Old 01-23-2017, 05:25 PM
Mayhem's Avatar
0/11 ssssss175
How is it will smaller vehicles? Like a sedan with the sub firing into the cabin.
I fart at 30hz
Old 01-23-2017, 05:51 PM
0/11 ssssss313
I was going to do subs up port back also it's a minivan and I'm unclear should I tune lower or higher with a mini van or bigger vehicles
Old 01-23-2017, 06:12 PM
mega fatty
0/11 sssss6008
It doesn't change the tuning
It changes the cabin peak
Unless you put the port close enough to a wall that it acts as part of the port
If you want 28hz tuning tune the box to 28 and it will get low
Old 01-23-2017, 07:15 PM
0/11 ssssss313
Think I got it thanks
Old 01-23-2017, 07:33 PM
Omegakan's Avatar
0/11 sssss1147
Feedback Score: 53 reviews
Playing around with box confirmation and placement is much cheaper and beneficial than a total overall. Testing and placement is top tear with learning a specific vehicle.
Old 01-23-2017, 07:34 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
A minivan?
Seems more and more guys driving soccer mom vans. WtF is up with that?!
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 01-23-2017, 07:42 PM
jeffdachef's Avatar
0/11 ssssss440
Originally Posted by Boomintahoe View Post
A minivan?
fits more subs, powerful suspension. If a van was meant to carry eight 200lb people, it can carry a big system no problem.
In my sienna I'm tuned to 36hz and it still plays down to 19hz subs up port back. Peaks around 38-43hz where i like it but hits 22hz hard as well. In smaller cars I find it a lot harder to hit the lower notes anywhere as authoritive.
Old 01-24-2017, 09:08 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
subs up port up ftw. that boomy low and slow bass doe
team graham
box size and tuning for an 05 re xxx bikerdc17 General Car Audio Discussion & Questions 2 09-06-2011 05:40 AM
HDC318 Box Size and Tuning Nebraskachevy General Car Audio Discussion & Questions 11 07-09-2011 03:56 AM
SA-8 ported box tuning size etc? AR-15 (Sundown Audio) 6 05-03-2011 04:55 PM
Finding the size and tuning Bobby32 General Car Audio Discussion & Questions 0 05-22-2010 08:21 PM
What tuning frequency and size lunari Enclosure Discussion & Design Construction Help 12 07-11-2009 05:04 PM
