What are common walls and how do you calculate box bracing - Car Audio Classifieds!
Old 02-03-2017, 09:34 AM
0/11 ssssss313
Default What are common walls and how do you calculate box bracing
What is a common wall and how do you figure out how many you have? I'm also trying to figure out how to measure box bracing
I'm using "the ultimate car audio app" to attempt my first box designed myself (anybody use it btw)
Old 02-03-2017, 09:46 AM
0/11 sssss1417
A general slot will use 3 walls. Where the port touches three walls of the box. For instance the pic below is 1 wall since it's only using the bottom and not the sides.
Team Scoshe
Team Sears
The Following User Says Thank You To stealth For This Useful Post:
stealth(Today)
The Following User Says Thank You to stealth For This Useful Post:
Maniac (02-03-2017)
Old 02-03-2017, 10:08 AM
0/11 ssssss313
I think I get it thanks
Old 02-03-2017, 10:09 AM
Austin175's Avatar
0/11 sssss4224
My box has a slot port(drivers side) but doesn't make an L, so I believe it would be 2 common wall as it only touches the top/bottom pieces of my box.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 02-03-2017, 11:00 AM
0/11 sssss8594
Feedback Score: 55 reviews
0 common walls is a port that is floating, not touching any walls except the 1 its mounted to
1 common wall is like a bottom port, like stealths picture
2 common walls is like an L port but with NO bend, just straight back
3 common walls is your standard L port
Enclosures
The Following 2 Users Say Thank You to fyerbyrd22 For This Useful Post:
Austin175 (02-03-2017), jigsizzle (02-03-2017)
Old 02-03-2017, 11:15 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Good info here...
Sent from my SAMSUNG-SM-G530AZ using Tapatalk
Old 02-03-2017, 11:18 AM
0/11 sssss8594
if i can find some good example picture later, i will add them...there was a thread on SMD that covered this via the Torres Calculator and Sketchup, however the links do not work anymore i believe
Enclosures
Old 02-03-2017, 11:30 AM
doug118's Avatar
0/11 sssss4674
The last 2 are just confusing and I know what common walls are
2 common walls would be a center vertical port, using the top and bottom baffles as port walls
3 common walls would be a side slot port, using top, bottom and outside
The Following User Says Thank You to doug118 For This Useful Post:
Silver03gt (02-04-2017)
Old 02-03-2017, 11:57 AM
0/11 sssss8594
2 common walls is usually a center port that doesnt bend but a side port as well, with no bends is 2 common walls
and i dont see how i could describe it any simpler than a L slot lol
Enclosures
Old 02-03-2017, 02:36 PM
jeffdachef's Avatar
0/11 ssssss440
a side port with no bends is still using top, bottom and side wall so it still counts as 3
only a center straight port can count as two as that is just top and bottom.
The Following User Says Thank You to jeffdachef For This Useful Post:
A few questions.. common chamber walls? Racerkid15 General Car Audio Discussion & Questions 7 08-10-2012 01:29 AM
port no common walls confusing me drsnazzy General Car Audio Discussion & Questions 6 05-22-2012 04:03 PM
Will I need bracing for this box? DevinG17 General Car Audio Discussion & Questions 11 02-25-2012 07:24 PM
2 or 3 Common Port Walls? nicholask1993 Enclosure Discussion & Design Construction Help 2 10-21-2011 12:54 PM
Box bracing resko1 General Car Audio Discussion & Questions 7 10-07-2009 03:00 PM
