need some help on changing tune - Car Audio Classifieds!
Old 04-14-2017, 04:19 PM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
Default need some help on changing port area
im new to enclosure design we are trying to figure out what works best for the crossfire c7-12's . manufacture recommends 2.25 net per driver with 11 sq in of port or so and that simply wont work for my build.
plan is 8-12's on 4 sq 4500.1 amps . the test box is 2 cube net per and iirc 15 sq in of port box does a solid 153 on 5k which i can deal with but subs get warm quick on clean power so i want to drop a little port area
i have heard you can add wood in the port to decrease but does the wood need to be as deep as the port baffle or can i get away with simply adding sort peices ?
Old 04-14-2017, 05:34 PM
Whatever you add should probably extend the length of the port. Just sticking a random piece of wood in the port will probably show a decrease in tuning simply because of the added resistance to the port air plug movement, but it will also hurt port efficiency and will be entirely unpredictable.
Also keep in mind that reducing port area will make the port less efficient and lowering tuning will do the same, so I would expect a lower score on the meter. Less efficient ports will get you more cone movement though so it might help a tiny bit with cooling, but I doubt it will be more than a degree of difference.
Old 04-14-2017, 06:48 PM
caloriu's Avatar
0/11 sssss2863
im sorry the way i phrased it above was not what i meant im fine with the tune i just wanted to follow manufacture suggestions that subs have way too much port area . it peaks at 40 hz and is great for daily music wise i just wanted to drop port area down as instructed.
i have heard of guys claiming to add wood in the port to shrink i just did not know how its done. i was not just going to throw a random piece it i was thinking going from 46.5 wide port to 45 .
again this is simply for testing
Old 04-14-2017, 10:34 PM
Gotcha. I see what you're saying- just slide in a piece to reduce the width. As long as the piece you slide in is the same length as the port that will lower tuning like you want.
changing the plans - when is enough enough brian84corvette Off Topic Chat 3 08-08-2014 08:02 PM
changing font. btsteinb Off Topic Chat 3 04-02-2013 08:47 PM
changing subs Blaza33 General Car Audio Discussion & Questions 21 03-28-2013 06:17 AM
I am SO changing my major. F3M4 Academic Section 3 03-25-2010 07:17 PM
Changing pulleys crownvicon26's General Car Audio Discussion & Questions 8 12-30-2009 08:23 PM
