Daily / Spl Trunk wall enclosure - Car Audio Classifieds!
Old 04-27-2017, 02:27 PM
0/11 ssssssss9
Default Daily / Spl Trunk wall enclosure
I have a 2013 Honda Civic. 4 door trunk car. I am looking for a permanent type of enclosure what can do daily and spl on the weekend? What is the best type of enclosure to do this with? Maybe and 8th order or what do you think? Subs are (2) DSS Ethos 12's
Old 04-27-2017, 02:40 PM
Frank's Avatar
I like twins with A$$
0/11 ssssss377
I would use a aero port!! Tune low for daily, and high for comps.
youtu.be/SWV9r9USAeA (IJUSTWANTTOGETLOUD)
Old 04-27-2017, 02:50 PM
0/11 ssssssss9
Default ?
just a simple ported enclosure?
Old 04-27-2017, 03:42 PM
Red Light Ear Rapist
0/11 sssss1397
Never have heard of a daily 8th.
Old 04-27-2017, 03:43 PM
0/11 ssssssss9
Default daily 8th
something like an abc box?
Old 04-27-2017, 04:23 PM
Frank's Avatar
0/11 ssssss377
Believe it or not a aero port box is simple!!
Old 04-27-2017, 05:23 PM
mega fatty
0/11 sssss6008
idk if you could fit a 8th for 2 12's in a trunk much less have proper orientation to utilize it.
trunk wall with interchangeable ports would be good.
07 mazdaspeed3
rd d9 @ .5ohm
Old 04-27-2017, 05:55 PM
The general rule of thuimb (for a "perfect" speaker) is that for the same size total volume of enclosure and same power, as get more peak gain and less bandwidth as you move up in orders. An 8th could get really loud and for a trunk-sized build probably peak in the 60ish hz range if not higher, and with "heavy" subs that are not perfect transducers you start fighting inductance losses as you get higher in frequency so it might not even peak as high as a lower order enclosure at a lower frequency.
Old 04-27-2017, 11:30 PM
So Low's Avatar
0/11 sssss1258
A small vehicle like that has such a huge cabin gain down low that you don't need anything fancy to get low end extension just from a simple 4th order or ported box.
Build a 4-5 cubic box tuned to 34-36 hz ported to the driver's side of the trunk. As much port as you can fit. Add lots of power, and you will be loud.
Old 04-28-2017, 01:18 AM
Dmuney's Avatar
0/11 ssssss101
If I were you I would make it a walle/ sealed off trunk That's how I did my civic 6cuft lots of port tuned to 28hz 2 SA-12's 1400 rms old school power and let me tell you DA.DA.DANG I was more than pleased
Enclosure Build: 12" 'standardized' daily enclosure, Dougie style Pioneer~Saturn Build Logs 59 05-20-2013 05:32 PM
Daily SPL: DD3512s, or Mach 5 SPL-12s? Ronmeister General Car Audio Discussion & Questions 2 02-11-2012 09:22 PM
wall in a daily driver focusedfornow General Car Audio Discussion & Questions 2 02-08-2012 01:19 PM
second battery in trunk for daily. 4KW. MERQUE General Car Audio Discussion & Questions 33 12-04-2011 08:57 AM
Sub/port up in a trunk: does it work for daily? 1ndatrunk Enclosure Discussion & Design Construction Help 11 08-17-2010 10:04 AM
