weird issue with peak frequency - Car Audio Classifieds!
Old 06-13-2017, 02:56 PM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
Default weird issue with peak frequency
i have a dbl layer box tuned to 33 hz , previous subs were crossfire 8c7 -12 and peak frequency was 50-55 depending where i position the box . although box peaked higher it seemed to be normal played lows .
now i switched over to sundown 8 sa 12 and my peak went down to 30-31 depending where i position the box , i think this is very odd .
box is 48 w x 36 d x 25 tall double layer 3/4 birch all around, baffle is triple but subs are counter sunk . 4 -8 " aero 22" long . subs up port back . if im doing math correct tune is 33 hz with 13.75 sq in per foot and 14.77 net i only have a 5/8 rod top to bottom so i just did .25 for brace and displacement i figured 1.12
any info would be appreciated .
Old 06-13-2017, 03:44 PM
0/11 sssss1117
My math just basic adding up box dimensions minus the 2 extra layer of baffle/ sub displacement and port volume. I came up with 16.9 cu.ft net and I added up all 4 inch port area to roughly 208 sq.in. So with that I got 31.2 hz. This is all rough math not exact number but very close like 98% with in your actual box specs. But human error can be somewhere in there. I don't have my tablet to cross reference on Torres box calculator
Old 06-13-2017, 03:53 PM
caloriu's Avatar
0/11 sssss2863
i say its seems clsoe enough . still i dont understand how subs peak lower than actual tune . i mean the crossfire subs were in the same box and peak was 50 hz so i dont get why sundown dropped to 30 hz.
i ran a sweep with the termlab twice and its was at 30 . only thing i can think of subs were not fully broken in but usually they play higher not lower idk
Old 06-13-2017, 04:26 PM
0/11 sssss1117
From my experience I notice a whole difference in bandwidth from ai death penalty to hdc3 peak went up but I didn't have a meter to see how to be exact. But sounded totally different. As for peaking below box tuning I would think because it's load off the rear panel.
Coul be from not being broken in. Parameter are different/motor force and all. But it's confusing if they both graph the same and then totally sound different. Something I won't understand fully. Guess I will take a physics coarse or get some lesson on sound acoustic
Old 06-13-2017, 04:34 PM
caloriu's Avatar
0/11 sssss2863
i understand they will sound different .
its weird becuase 1 it peaks very low and i got a 155 @ 55 hz sealed on the dash and now i did a 155 at 31 hz . i have never been able to get my van louder on low frequency. i usually shoot for 35-36 tune and peak 45hz - . this particular box peaked high with the crossfire and reverse really low with the sundown .
in both scenario vehicle was the same as was box position
its weird jacob , thought its odd as well
Old 06-15-2017, 05:12 PM
0/11 ssssssss6
It could be your vans acoustical tuning is lower than the box frequency ?
SUNDOWN FTR
Old 06-15-2017, 07:44 PM
caloriu's Avatar
0/11 sssss2863
SUNDOWN FTR
actually was a phantom peak, for some reason my 4th aero port was screwing with me . with 3 aero peak was 38 added the 4th peak went to 31 . lucky enough i had a buddy on facebook who was able to help me figure it out.
good thought tho ,thanks
Old 06-15-2017, 11:25 PM
mega fatty
0/11 sssss6008
Did you try any higher?
Maybe your van peaks near 60 but is hitting a second peak an octave below
Old 06-16-2017, 06:37 AM
caloriu's Avatar
0/11 sssss2863
i never did go up quite that high . i think i did up to 55 with all 4 ports plugged and found 41 was the resonant frequency . i then started opening ports 1 by one and score keep going up considerably and peak down by like 1 hz. the last port removed gave me little gain but dropped peak way down
Weird 80prs issue TaylorFade General Car Audio Discussion & Questions 18 01-15-2014 06:33 PM
Weird issue Beatdown337 General Car Audio Discussion & Questions 13 11-01-2013 01:51 PM
weird issue. IAWJ4.7 General Car Audio Discussion & Questions 23 01-21-2013 07:42 PM
peak frequency for my car jb livewire General Car Audio Discussion & Questions 1 10-04-2012 03:28 AM
Peak frequency of car change with box style jfoodstamp General Car Audio Discussion & Questions 5 09-28-2011 10:48 PM
