Blow-throughs... - Car Audio Classifieds!
Old 10-28-2008, 08:39 PM
RE_Gawker's Avatar
0/11 ssssss682
Default Blow-throughs...
I am seriously thinking of doing a blow-through in my truck and not sure if I want to go with the usual way or the camper shell way.
With the camper shell I could do it without causing any damage to my truck and It would look really cool when inside the truck. This would be expensive because I am having troubles finding pewter camper shells and I would also have to tint it all around, and I think a camper shell on my truck would look stupid.
With the normal bed top I would have to cause permanent damage to my truck, and also I would have troubles with the setup because I want to put my back seat back into my truck and most people cut a squarish hole and my seat would get in the way. This way would make my truck easier to drive(I end up backing a lot of trailers and waverunner trailers are a bitch to back by just using side mirrors.)
The second way would probably be easier to build as more people have done it and I have seen a few build logs of them.
If I go with the second route I am thinking I will have to do it like this guy did it.
SSA Forums: Blow-through in my bagged 95 fullsize chevy
Currently I have 2 audioque HDC318's and I am wanting to go with 4, which would be probably be harder to do with the 2nd way.
Any helpful input or suggestions on this would be awesome.
EDIT: Read post 24...(wanting any and all pics or buildlogs of blowthroughs)
Old 10-28-2008, 08:49 PM
RE_Gawker's Avatar
0/11 ssssss682
Originally Posted by SPL Guru View Post
Is this gonna be for comps or more for enjoyment?
Depending on the boot size you put in, you could have it lower to let more air go under the rear seat.
Personal enjoyment.
I don't mind cutting a large hole but I am worried that the larger hole will cause problems with the rear seat in.
And yeah, I think that I will have to do it lower to avoid the rear seat but then I don't think I will be able to do 4 subs, unless I go with a 4th order...
Old 10-28-2008, 08:54 PM
RE_Gawker's Avatar
0/11 ssssss682
YGMP
replied
Old 10-28-2008, 11:29 PM
mytyeerinpie's Avatar
Elite Master Member
0/11 sssss6375
did you figure it out?
Posted to Monty
as it is you would have been better off with a 50cc hot pink moped with slutty on the plate
im sry bro but actions like this bring down you and the whole site....this is a place to help and or learn car audio along with selling used car audio equipment.....posting to get a rise out of ppl is not only childish it hurts caco on the whole.....
Old 10-29-2008, 12:10 AM
RE_Gawker's Avatar
0/11 ssssss682
Still not sure which way I want to go, I have been thinking about it for a couple weeks off and on but haven't made a decision.
The starting cost for the traditional blow-through will be about 500-1000 dollars cheaper depending on if I can find a used pewter camper shell or not.
It's not the blue pewter, it's this color(my truck as it sits)
Should be a pretty common color for camper shells but I am having some troubles finding them used in this color.
Old 10-29-2008, 12:40 AM
forceww's Avatar
0/11 sssss3264
you should buy a tool box for your truck, gut it, use it as a box, and use that in your blow through. Nice and stealthy
ANOTHER New System
Team SBC-Team CACO-Team Lethal Beatz
plenty of refs just ask
Old 10-29-2008, 01:23 AM
RE_Gawker's Avatar
0/11 ssssss682
bad thing is that they aren't waterproof, a lot of moisture gets in them over time.(also easy to break in to)
And the size of the system I am wanting to put in is going to take up about half my bed, lol.
Old 10-29-2008, 01:29 AM
forceww's Avatar
0/11 sssss3264
lol good choice. GOIN BIG
ANOTHER New System
Old 10-29-2008, 07:57 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Make it a custom bed, a gigantic fiberglass wall with door to walk inside to change the volume for comps, lmao.
My Car, My Ears.
Old 10-29-2008, 08:04 AM
forceww's Avatar
0/11 sssss3264
stick to sq sir jk luv ya nizzy
ANOTHER New System
Avalanche blow thru bones22 Build Logs 29 12-04-2008 07:33 PM
Will wiring 4 ohm sub to 8 ohm home receiver blow the receiver up? tahoebrotha General Car Audio Discussion & Questions 6 12-01-2008 05:07 PM
Avalanche blow thru bones22 Build Logs 38 10-01-2008 10:09 AM
