resin inside box - Car Audio Classifieds!
Old 12-17-2009, 05:57 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
Default resin inside box
I've seen some people put layers of resin inside the box but never understood why?
- CALI SOUNDS
- VERTEX AUDIO
0/11 sssss6075
Smooove
gbo559's Avatar
Veteran Member
0/11 sssss4814
WHAT
- CALI SOUNDS
- VERTEX AUDIO
Old 12-17-2009, 05:58 PM
cuseikan's Avatar
habitual line stepper
0/11 sssss1207
Originally Posted by terra View Post
Smooove
x2
gbo559's Avatar
Veteran Member
0/11 sssss4814
What x2
- CALI SOUNDS
- VERTEX AUDIO
Old 12-17-2009, 06:01 PM
lowered :D
0/11 ssssss102
Mdf is pourus, Fibreglass takes that pourus and makes it "smoove" as the above has said
pros:
smooths the box out
seals all the edges
seals the wood it's self
cons:
doesn't add strength
more weight
messy as hell
takes to long to dry imo
Old 12-17-2009, 06:03 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Originally Posted by wenn_du_weinst View Post
pros:
smooths the box out
seals all the edges
cons:
more weight
messy as hell
would you recommend doing it? I thought it added strength to the box.
- CALI SOUNDS
- VERTEX AUDIO
Old 12-17-2009, 06:04 PM
cuseikan's Avatar
0/11 sssss1207
I started trippin out on the fumes coming off of my box when I resined the inside of my box. I smelled it for a good 2weeks after I applied it.
Old 12-17-2009, 06:05 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
ok im not doing it lol. I can't stand weird/unusual smells in my car
- CALI SOUNDS
- VERTEX AUDIO
removing fiberglass resin from plastic? kurrupt General Car Audio Discussion & Questions 1 11-02-2009 03:34 PM
where to fine good cheap resin? waresgaragestereo General Car Audio Discussion & Questions 15 10-05-2009 12:23 PM
Resin on the inside of the box? Worth it? CleanNMean General Car Audio Discussion & Questions 0 09-30-2009 09:46 AM
Fiberglass resin ??? KHARPS General Car Audio Discussion & Questions 9 07-11-2009 06:03 PM
enough hardner with my resin? waresgaragestereo Sound Deadening & Fabrication 13 02-04-2009 06:21 PM
