Problem with new box z4 15 - Car Audio Classifieds!
Old 07-22-2017, 09:09 AM
0/11 sssssss33
Default Problem with new box z4 15
I bought a new box design-caraudiofab
but unfortunately
Something does not work
It sounds weaker
It does not have the power I'm supposed to feel on my body
But I found out When I open the door The of trunk
Everything changes
for the better
Sounds strong
What could be the reason?
An old box
The volume is not enough
New box8.50_32HZ
TY
Old 07-22-2017, 09:29 AM
doug118's Avatar
0/11 sssss4674
Your first problem is the subs and port shouldn't be firing forward. Flip the box around and fire put the subs about 1' away from the hatch
Old 07-22-2017, 10:17 AM
massivespl's Avatar
0/11 sssss8409
Either point the box backwards. Or if ur going to keep it forward u need to wall it and seal it off lol
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 07-22-2017, 11:56 AM
0/11 sssss1117
Make sure you do have both sub in phase of each other. I accidentally did that and audibly didn't get any sound. I swapped the one set of wire to match the other sub
Old 07-24-2017, 04:44 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Face the box backwards...
Old 07-24-2017, 07:25 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Since it wasn't mentioned, that's a bad spot for the amp mount. I would find something to go in between the mounting feet/holes of the amp and to the box/enclosure. Thus, will prevent amp vibration which will kill that expensive amp. Or find another spot to mount....but looks like you got a tight situation there.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 07-26-2017, 10:43 AM
0/11 sssssss33
OK
Where should I start the wall
You can recommend to me from which point
According to the picture
Old 07-26-2017, 07:08 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I would seriously fire it rearwards before you try and wall it off.
The Following User Says Thank You to jt_buck For This Useful Post:
massivespl (07-26-2017)
Old 07-27-2017, 11:41 PM
0/11 sssssss33
OK
I turn the box backwards
My problem
the box sit at the same distance
Something like 21 "from the back door
Because I have an opening there
Sitting there
amplifier sundown 4+125
And battery D7500
It really matters
Distance?
ty
Old 07-28-2017, 06:43 PM
bassfreak's Avatar
0/11 ssssss597
put a false wall to block the pressure from going behind the face of the box you will gain 3 to 4 DB..
bass-box problem bassman_soundking Enclosure Discussion & Design Construction Help 4 09-04-2013 10:59 PM
Is this a problem?... xnewbx General Car Audio Discussion & Questions 4 03-02-2013 03:57 PM
torres box tuning problem Russellabt General Car Audio Discussion & Questions 2 03-26-2011 02:18 PM
box problem tymoto21 Enclosure Discussion & Design Construction Help 5 10-18-2010 12:58 PM
problem with 3kwp [Problem Solved] jizazz12 (Crescendo) 10 04-30-2010 06:46 AM
