Can someone model a 18" Dayton Ultimax?? - Car Audio Classifieds!
Old 10-01-2017, 09:16 PM
0/11 ssssss369
Default Can someone model a 18" Dayton Ultimax??
I was hoping someone could model my Dayton 18" Ultimax for me. I will be using a Elemental Designs Nine.1 which does around 14-1500rms at 1 ohm on good electrical. Im wanting to know approx how many cubic feet it will require so I know if I can make it work with the space I have available. Specs on the woofer are below:
Product Specifications
Nominal Diameter18"
Power Handling (RMS)1,000 Watts
Power Handling (max)2,000 Watts
Impedance4 ohms
Frequency Response19 to 500 Hz
Sensitivity88.6 dB 2.83V/1m
Voice Coil Diameter3"
Thiele-Small Parameters
Resonant Frequency (Fs)19.50 Hz
DC Resistance (Re)4.4 ohms
Voice Coil Inductance (Le)2.22 mH
Mechanical Q (Qms)3.82
Electromagnetic Q (Qes)0.62
Total Q (Qts)0.53
Compliance Equivalent Volume (Vas)7.49 ft.³
Mechanical Compliance of Suspension (Cms)0.10 mm/N
BL Product (BL)23.8 Tm
Diaphragm Mass Inc. Airload (Mms)655g
Maximum Linear Excursion (Xmax)22 mm
Surface Area of Cone (Sd)1,219 cm²
Refs: Austin175, SkarAudio, Richard, ampaddiction, r1 banshee, wcjake15
Old 10-04-2017, 12:18 PM
0/11 sssssss39
Bigger the better for the 18" Ultimax. 4ft3 net if cramped for space, but 5ft3 net for output. Tune of 28/29hz
The Following User Says Thank You to neillio For This Useful Post:
White91Formula (10-04-2017)
Old 10-04-2017, 12:22 PM
0/11 ssssss369
Thanks man, did you model it in winisd or bass box pro?
Also, just curious, have you ran this woofer before (In an automobile)??
Sent from my iPhone using Tapatalk Pro
Old 10-04-2017, 01:24 PM
0/11 sssssss39
winisd
I've used the Dayton Titanic MkIII and Ultimax 12" in a vehicle. The Titanic I used in my Jaguar S-Type back in 2010. Went with 2.2ft3 net @ 33hz. Diamond D5 600.2 amp bridged. The Ultimax I installed in a friend's Trailblazer. Went slightly larger at 2.4ft3 net and a 31hz tune. He powered it with a Cadence ZRS C2. Hit the lows with accuracy and authority.
Old 10-04-2017, 01:32 PM
0/11 ssssss369
Good to hear man! I'm definitely looking forward to putting this 18 in the winter truck. 99' GMC Sonoma extended cab. I'm going to face the woofer at the back of the seats and fire the port towards the roof. From the research I've done that seems to perform the best in this style of truck.
Old 10-04-2017, 02:33 PM
0/11 sssssss39
That sounds right. Should get a decent amount of flex in that smaller truck cab.
dayton ultimax korey_hofer Sound Quality Area 4 05-22-2014 02:33 PM
(4) Dayton 6.5 & (2) Dayton 1 1/8" Tweeters 99xtremedime Component & Coaxial Speakers 10 02-04-2013 09:56 PM
Dayton Ultimax Subs Matt3824 General Car Audio Discussion & Questions 14 01-21-2013 09:15 PM
Dayton Concours d'Elegance at Carillon Park ~ Dayton OH ~ 09-14-2008 Patrick Simmons Car Show Feeds 0 09-12-2008 01:27 AM
