Sealed enclosure Questions/problems? - Car Audio Classifieds!
Old 12-20-2009, 03:46 PM
BlueLude's Avatar
WHAT??!!??
0/11 ssssss566
Default Sealed enclosure Questions/problems?
I bought 2 TC 1000's 8"s from Spy a few months ago and just got around to building a enclosure. I decided to go with a sealed setup since I am pretty limited on room. The box is a 28x10x10" box, roughly 1.1 cf before dispalcement, which seemed okay since the recommended size was .3-.7 sealed.
Problem: So I finish the box and hook it up to the [email protected] ohm. The first thing I noticed is there sounds to be air leak between the basket and box. the second thing I noticed is they look like they are beating but like zero output, the midbass is over powering the subs.
Question: Is the design of the box okay or is this causing my problem and will an air leak effect the sound of a sealed enclosure this much? or do I have more problems than just a crappy box design
The only picture I have of the box right now, tye has more on his camera maybe he will be a sweetheart and upload them for me :
I will probably end up going ported and will most likely invert the subs cause it is a real pain getting the holes just right to clear the basket but still have wood to screw into.
Cut that shit out brian......I'll e-thug you from iRAQ
Old 12-20-2009, 04:54 PM
0/11 ssssss218
weather seal between sub and box, make sure your subs are not out of phase, it wont hit hard if it is leaking and seal boxes use half the power as ported and dont hit as hard.
Old 12-20-2009, 04:58 PM
DonH's Avatar
0/11 sssss6645
Feedback Score: 30 reviews
u did not cut the cutouts to big right?
SHABAM
Old 12-20-2009, 05:01 PM
statonburrell's Avatar
go big or go home
0/11 sssss1896
sounds to be out of phase..
"Though the road has been hard as the day is long, I wouldn’t trade in a second. The strength that’s allowed me to endure doesn’t come from what you see--the thick slabs of meat, veins thick as rope, skin so thin the grainy fibers show. No, it runs deeper. To get to it, you’d have to cut away all the layers of doubt and distraction till knife hits bone. The seconds are passing by. Find that itch... Scratch till there’s nothing left."
Old 12-20-2009, 05:07 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Air leaks will kill sealed boxes.
/ CAAA Member #2 /
SPY SPY is offline
0/11 ssss10192
/ CAAA Member #2 /
Old 12-20-2009, 10:48 PM
BlueLude's Avatar
WHAT??!!??
0/11 ssssss566
I think this may be my problem, how to check/fix?
Old 12-20-2009, 10:54 PM
0/11 ssssss218
switch pos and neg. or take a 9 volt battery and see which why the sub is moving
Old 12-20-2009, 11:01 PM
BlueLude's Avatar
WHAT??!!??
0/11 ssssss566
Will the 9v batt work with both wired together?
Old 12-20-2009, 11:03 PM
0/11 sssss6075
Should do.
Enclosure Build: Sealed for 12" Pioneer~Saturn Build Logs 4 01-10-2011 09:25 PM
'02-'06 Nissan Altima Custom Sealed Enclosure duramaxxed Wiring, Electrical & Other Installation Equipment 8 11-26-2009 09:49 PM
Dual 12", Sealed Enclosure Build Pioneer~Saturn Build Logs 2 03-06-2009 05:45 PM
[BASIC] Designing a Sealed Enclosure danteBirosel Tutorials & Quick References 1 11-12-2008 03:34 PM
