How do I find the volume for this weird shaped box? - Car Audio Classifieds!
Old 08-02-2019, 09:04 PM
newarkbeast973's Avatar
0/11 sssss7810
Default How do I find the volume for this weird shaped box?
Looking for ideas for my new set up. Thinking of doing a small (very small) set up but want it to sound and look good.
I have a very small space between my rear seat and trunk that I would like to use for a 6.5 sub. Im trying to see if I have enough space to even do it in the given space. And if I do, if I can do porter or have to stick with a sealed enclosure.
This is a picture of what Im working with and the measurements.
With 4 depth.
New build coming soon!!
Old 08-04-2019, 02:32 AM
0/11 ssssss100
you just have to break it down into as many squares as you can for a mathematical answer. Or fill it with a couple of gallon pitchers of pinto beans, or a plastic bag and water. 1 Gallon is 231 cubic inches. flies away
The Following User Says Thank You to tater6061 For This Useful Post:
iamsonic (08-04-2019)
Old 08-04-2019, 02:46 PM
0/11 ssss31247
calculate it as a 17" x 28" rectangle {476sq in}
then subtract the 11" x5" of the corners {55sq in}
421 sq in
then multiply it times 4" deep
1684 cu in
then divide by 1728 cu in / cu ft
0.9745 cu ft
