2 12" box design. whats it tuned at? - Car Audio Classifieds!
Old 12-25-2009, 11:27 PM
ckaiser1688's Avatar
0/11 ssssss300
Default 2 12" box design. whats it tuned at?
ok so the box is 4.028 cubic feet. 34" wide, 16 1/2" tall, 18" deep. double baffle on front for the subs. the two aero ports are 4". does anyone know what this box would be tuned at? is there a certain way to determine tuning for aero ports?
HU- Kenwood Excelon x794 : Sub-2 12" Skar VVX
Amp-Sundown SAZ 2500d : 4.3 cu ft box tuned to 30
BEST TL: 142.1 sealed on the dash
Old 12-25-2009, 11:29 PM
0/11 ssssss300
Old 12-25-2009, 11:30 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
how long are the aeros
- CALI SOUNDS
- VERTEX AUDIO
Old 12-25-2009, 11:34 PM
0/11 ssssss300
how long would they need to be? like 8" or longer or what? i want to tune it around 32 hz - 40 hz. sorry im new to the aero ports.
Old 12-25-2009, 11:36 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
for 34hz tuning make each port 12.64
use the psp calculator
Products Menu
type in 4.02 for box cubic feet
whatever number you want for tuning
port diameter as 4
# of ports as 2
it will give you results for both straight length and flared
- CALI SOUNDS
- VERTEX AUDIO
Old 12-25-2009, 11:39 PM
0/11 ssssss300
Products Menu
port diameter as 4
# of ports as 2
wow thanks. that helped alot. i typed in 36 hz and its exactly 10" so then it would be 10" of the aero going into to box?
Old 12-25-2009, 11:43 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
I believe you have to cut each port to 10"
- CALI SOUNDS
- VERTEX AUDIO
Old 12-25-2009, 11:44 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
are you using flared aeros?
that calculator gives 2 lengths, one for non flared aeros, and one for flared
- CALI SOUNDS
- VERTEX AUDIO
Old 12-25-2009, 11:48 PM
0/11 ssssss300
probably flared. but if i go with straight all i gotta do is cut it 1" smaller so i might do that so i dont loose that much space in my box
Old 12-25-2009, 11:52 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
you don't lose much with aero's. IIRC they usually take up about 0.2 cu ft each or around that somewhere. Go with flared ports inside and out, that 1 inch longer length won't hurt you much, and it's best to go with flared aeros instead of regular aeros
- CALI SOUNDS
- VERTEX AUDIO
whats this tuned at? biscuit Enclosure Discussion & Design Construction Help 6 09-01-2009 07:40 PM
Figuring what a box is tuned to... Patrick Simmons Enclosure Discussion & Design Construction Help 8 09-01-2009 02:57 PM
AudioQue HDC3-A 15" vs Digital Design 9500g 15" redrum General Car Audio Discussion & Questions 9 07-09-2009 12:52 AM
how is this port tuned BassikInstincts Enclosure Discussion & Design Construction Help 4 04-10-2009 11:07 PM
Getting sick... Whats your "Remedy" Patrick Simmons Off Topic Chat 7 10-13-2008 11:16 AM
