Please Look Over! - Car Audio Classifieds!
Old 12-27-2009, 12:59 AM
strpperpolef150's Avatar
Ladies love my pole
0/11 sssss3814
Default Please Look Over!
I started messing around in BBP6 and came up with another design for my truck. I then opened up sketchup and started designing how I wanted it. I came up with a finished design but I think I made the port too long. I need someone to look over the design and see if its correct. I can email the sketchup file if needed.
The dimensions are:
14 H x 50 W x 8 TD x 11 BD
Port:
12.5 H x 2 W x 34.5 L
its suppose to be 1.75 cuft @ 33hz w/ 25 sq inches of port
Here are the sketchup images:
I need this asap because if this works out I'll be building it in the next few days.
-Single cab F150-
HU: Kenwood KDC-X993
Processing: Clarion EQS746
Front stage: (2x) Shok CB 6.5
Comp amp: Crescendo 1000C4
Sub stage: (2) AQ HDC3 10s in 2.3 cuft @ 38hz
sub amp: (2) SAZ-2500s strapped @ 1
Electrical: Mike Singer 250a alt, D3100, (2) NSB90, 70+ft of shok
New numbers coming soon.....
I buy shifted motors
- Team PSI - Team Shok -
Louisiana/Mississippi Crescendo Rep
Old 12-27-2009, 01:01 AM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
The angles will mess up your port length, your best bet is to run the port along the back wall of the box.
/ CAAA Member #2 /
Old 12-27-2009, 01:04 AM
Ladies love my pole
0/11 sssss3814
I was aware that the angles will affect the port length but am curious by how much. Is it a bad idea to do? Reason I am trying to layout the box this way depth limitations and not wanting the port opening to close to the sub. I have kept everything on the same angle also.
-Single cab F150-
Old 12-27-2009, 01:08 AM
SPY SPY is offline
0/11 ssss10192
It will affect the port quite a bit. It looks as though you measured your port length on the bottom (longer) side of the box, now measure the port length on the top of the box and see how much shorter it is.
If you want to keep the port opening away from the sub just make the port go 1/2-3/4 the way to the sub and then turn back towards the side.
/ CAAA Member #2 /
Old 12-27-2009, 01:11 AM
Ladies love my pole
0/11 sssss3814
I've heard that with angles is you measure the middle then you will get an approximate length. Is there any truth to this?
I didn't even think about having it curve that way. I will play around with that.
-Single cab F150-
Old 12-27-2009, 01:12 AM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
i like the design... truck box t-line?
Old 12-27-2009, 01:14 AM
Ladies love my pole
0/11 sssss3814
thanks.
no just a regular ported enclosure for my truck.
-Single cab F150-
SPY SPY is offline
0/11 ssss10192
Not really. you could probably get away with it was only the port opening but being that it's multiple sides of the port I really wouldn't suggest it.
/ CAAA Member #2 /
Old 12-27-2009, 01:15 AM
SPY SPY is offline
0/11 ssss10192
Not even close to a T-line.
/ CAAA Member #2 /
Old 12-27-2009, 01:16 AM
Ladies love my pole
0/11 sssss3814
ok well let me redo this real quick
-Single cab F150-
