my first box design - Car Audio Classifieds!
Old 12-28-2009, 02:49 AM
nuboot's Avatar
0/11 sssss1775
Feedback Score: 24 reviews
Default new measurements
well heres my first ever design using sketch up each of the sides are 26h x 15w x 45d for 8.3 cubes
and the opening area will act as the ported area and the measurement to the area is 26h x 25x 45d so iits about 650 square inches of port area and tuned to around 43 hz
so does that look and sound right
hopefully this box hit the lows do a possible hair trick and still put up decent numbers
VEHICLE: 2005 Trailblazer on 24s
WIRING: 8 runs of 1/0 knu gnd and pwr
BATTERIES: 4 Shuriken BT80s
AMPS: Team Cactus 5k
SUBS: undecided
Old 12-28-2009, 02:54 AM
for it to work like a 4th order you need to have loading walls
Old 12-28-2009, 03:00 AM
nuboot's Avatar
0/11 sssss1775
ok where would u put the loading walls
SUBS: undecided
Old 12-28-2009, 03:59 AM
nuboot's Avatar
0/11 sssss1775
ok here it is with the loading wall
SUBS: undecided
Old 12-28-2009, 04:51 AM
other way at the end
I would have told you sooner but wasn't home
the opening needs to be smaller than the chamber the subs fire into
Old 12-28-2009, 01:26 PM
nuboot's Avatar
0/11 sssss1775
ok i think i understand back to the drawing board what should it be tuned to so i can know how much smaller to make it
SUBS: undecided
Old 12-28-2009, 10:46 PM
nuboot's Avatar
0/11 sssss1775
so i took my old box with 3 15s out and finally got time to take some measurements
my intentions if i was to do a 4th order my sealed box would measure up to
45.5w x 33h x 24d which comes up to 18cubes
and for the ported area can be as big as 50w x 38h x 24d 23cubes so thats the space i have all options are available im looking to use alot of subs
so tell me what u got
SUBS: undecided
box design v2 RidnClean Enclosure Discussion & Design Construction Help 4 11-05-2009 09:07 PM
box design help RidnClean Enclosure Discussion & Design Construction Help 10 10-25-2009 10:09 PM
E8 box design. worstenemy453 Enclosure Discussion & Design Construction Help 0 06-11-2009 09:30 PM
my design korey_hofer General Home Audio/Video 9 12-26-2008 08:58 PM
Need help with my box design thecartel Enclosure Discussion & Design Construction Help 10 12-12-2008 07:02 PM
