Think this would be ok? Big box pieced together.. - Car Audio Classifieds!
Old 01-06-2010, 12:14 AM
0/11 sssss1741
Default Think this would be ok? Big box pieced together..
My idea on fitting two 9515's in my trunk. I have the space, however the trunk opening is not big enough. I already have a box for a single 15, about 4.6 cubes total size.
This is my plan, cut the front off of the current box. Will have to cut it off due to the front baffle was glued on and would destroy it anyways. I would just trim it right off and wouldnt make the box really any smaller.
Then i can put that part of the box into the trunk, then build another similar sized partial box and "piece" them together with some more mdf. This would all be glued and screwed together obviously.
This will not only save me some wood by using the current box, but its also the only possible way i can see getting sometihng of this size into my trunk. I am assuming this will work if its done decently, maybe add some bracing at least, and i want to double baffle the front piece also.
Hopefully these pics kind of show what my plans are, or atleast what im trying to say is understandable.
I would build it like that last pic shows, with the cross piece already in there then i can just screw the top piece onto the box. Maybe make the connecting pieces a little wider tho prolly would be better..
Old 01-06-2010, 12:15 AM
0/11 sssss1741
O and if you didnt assume, the top part of the box will also be two pieces due to the current box is glued together and will not come apart obivously. So it'll basically be piecing two boxes together into a big box.
Old 01-06-2010, 12:18 AM
indytrucks's Avatar
CACO Late Night Crew
0/11 sssss5387
Sealed?
Old 01-06-2010, 12:19 AM
0/11 sssss1741
Originally Posted by indytrucks View Post
Sealed?
No. I have not decided where im putting the port yet. I wont be able to place the port where i want, or wheres its prolly recommended but i know i can make it work one way or the other. The subs may not even end up going on that side of the box, who knows. Im just trying to figure out HOW to get the box into the trunk for now, i know i can make the port and sub placement work one way or the other.
Old 03-02-2010, 02:49 PM
0/11 sssss1741
ttt
would that be ok??
I think im going to put the port on top of the box, the oppose side of the subs obviously. Well i think this is the set up i am going to try. Hopefully it will work out fine, im sure it will.
Old 03-02-2010, 03:11 PM
0/11 sssss5305
I would consider doing 2 separate boxes that can be built outside the car. I "assume" this will be forward firing as you're going to block off the entire trunk.
You could also cut open the rear seat opening, take off a door and slide the box in from the front. That's how I did 2 15's in my Altima...
Old 03-02-2010, 03:24 PM
0/11 sssss1741
They still wouldnt go into the car, wouldnt fit through the trunk opening. The subs are going to be firing towards the rear, port firing up in back of box kinda like if it were to fire into the rear deck.
No way the box, or two boxes will fit in from the front with the seat off either.
mega fatty
0/11 sssss6008
if you do do it your way i would make the pieces all the way along the box, so like double baffleing...
it wouldnt be as strong as a true double baffle box but it would be sturdy,
why not build the box and slide it back in through the front?
07 mazdaspeed3
rd d9 @ .5ohm
Old 03-02-2010, 03:41 PM
0/11 sssss1741
That had crossed my mind, to just double baffle it instead, but thats alot more wood. I dono, ill see what i can do. But i dono how i would do the bottom piece. Also, one probelm is i plan to use my current box, just add on to it, and with the size it is, it cannot get any wider really, i think its about as wide as it can get. Ill check tho. There is no possible way it could go through the front, too big, not enough room.
