Important... Need help - Car Audio Classifieds!
Old 11-03-2008, 10:53 AM
0/11 ssssssss6
Default Important... Need help
Ok guys, one of the guys on this forum is going to build me an enclosure, and I need help coming up with a quick design so that I can tell him what I want. I have 2 15'' L7's that I am going to put in a 2000 Jetta (LOL, I know). So here is the problem. I wanted to port them at about 34-35 hz so they can get real loud. I spoke to a kicker rep today and read kicker's site and the rep told me that for the ported enclosure to work well it would have to be around 7 cub. ft. Kicker's site says minimum 6 cub. ft. I can only fit about 4.5 cub. ft. in my trunk. I was told that a sealed box built with the proper specs would give a higher output than a ported box which is too small... I read on the kicker site also that a sealed box will likely get real low (20-30hz)... and now I am starting to wonder how hard these bad boys can hit in such an enclosure. I know L7's are meant to get loud and dont have much SQ... so what do I do? I can only fit 4.5 cub. ft. in my trunk.... Can you guys please help me come up with a design that will give me the most output possible with the limited space... I need to get back to the person who is building the enclosure for me... Thanks.
Old 11-03-2008, 11:02 AM
tater's Avatar
Redkneck mechanic
0/11 sssss2732
could run just run 1 15 and give it 3.5 - 4.5 cubic ft
Old 11-03-2008, 11:06 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
x2
give it some room to breathe, dont do sealed
92 Ranger Walkthrough
(Under Construction)
Old 11-03-2008, 11:25 AM
forceww's Avatar
0/11 sssss3264
1 15 ported. 4 cu before displacement. Tuned lowww
ANOTHER New System
Team SBC-Team CACO-Team Lethal Beatz
plenty of refs just ask
Old 11-03-2008, 04:11 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Originally Posted by SPL Guru View Post
If hes building the enclosure, he should be able to get you the specs u need..
If not may wanna look elsewhere
He has the specs, I told him to post this up to see that me saying 2 L7 15's in 4.5ft^3 wasn't going to work wasn't just a suggestion.
Again I say sealed, but I'm not a basshead like some of these guys. Guru
/ CAAA Member #2 /
Important: i-Trader instructions Patrick Simmons Announcements - Suggestions - Feedback - Support 24 07-13-2010 12:50 PM
[MODERATE] Why is Subsonic Filter Important? danteBirosel Tutorials & Quick References 0 11-12-2008 02:43 PM
