4th order sub access... - Car Audio Classifieds!
Old 01-12-2010, 08:13 PM
Prohibited Sellers/Buyers
0/11 sssss2890
Default 4th order sub access...
Does any one have a design with a 4th order that you can access the sub easily if needed.
My space is 35wx30dx20t so no a wall a box. Just hate not being able to get to my sub easily if I wanted to like a normal ported box.. But I want to be sure it's sealed back up if I have to take the top off or something.
Any ideas?
Old 01-12-2010, 08:15 PM
0/11 sssss4714
Well couldnt you make the top so it bolts down with a rubber seal of some kind??
TEAM GORILLA
TEAM GHOST MOB
2007 Ford F150
1995 T-Bird P.I. 4.6L 312rwhp-Comp car,work car
Trunk Car class for 2011 MidwestSPL division!!
Old 01-12-2010, 08:18 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
big c is correct, thats probably the best way to do it. maybe having a panel big enough to fit the sub though.
Proud Member of CAAA!
Old 01-12-2010, 08:20 PM
0/11 sssss2890
That is kind of what I was thinking but was not sure what to use or if it would even work.
I was thinking the top on the sealed section of the 4th order be sealed sealed. The top where the port is be another peace that I could take off using screws. Since the wall separating the sealed and ported side would be double 3/4 MDF I could screws in really secure there splitting the 2 tops.
Just worried about it leaking there.. Seems simple but I don't want to waste a bunch of money on seals trying them out..
0/11 sssss7816
Theres a build on the rockford forums that has a silicon seal on the top.
I'd go that route if I were you
Atomic Loudspeakers
Audiotechnix
Old 01-12-2010, 08:23 PM
the best way to do it is a recessed panel and weather seal
Old 01-12-2010, 08:24 PM
0/11 sssss2890
Like what I said above? Thats kind of what I was thinking..
But then my port would be at the other end of the box so it would be like this..
__________
|sub| ] <---- Port
I was going to do
________ <-- port on top..
|sub| |
If I do side port this could work but top port seems like it might be really hard unless I do a 4th order with areo ports then it might be hard to really brace them if the top comes off.
DEAFWISH's Avatar
1 + 1 = 3?
0/11 sssss1018
I have a 4 15'' blowthrough 4th order BP in my daily driver. I use a "camper seal" on mine. It's about 1/8'' thick and come on a roll. I put it between the box and the top cover.
Old 01-12-2010, 08:25 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
pretty much what i was thinking. PE also has gasket tape you could use.
Old 01-12-2010, 08:26 PM
0/11 sssss2890
By recessed do you mean the sides screwing in to the top rather then top screwing down to the sides? Not sure if I under stood that..
Focal access vs. Pioneer primier Dbmonster General Car Audio Discussion & Questions 22 12-06-2009 01:41 PM
access to private sections 4 18"FI ssd Off Topic Chat 23 07-15-2009 05:14 PM
access to all threads sound_around Announcements - Suggestions - Feedback - Support 6 03-23-2009 03:33 PM
