future build - Car Audio Classifieds!
Old 01-14-2010, 01:10 AM
0/11 sssssss34
Default future build
now im horrible at geometry so please bear with me...
(after perusing the site, specifically the build log,i want to build another enclosure)
now currently i have an enclosure that is 4.55^3ft with port displacemnt (has internal slot port) and is 5.44^3ft with out any displacement.
im looking to build an enclosure in the future (but for the time being, i will be using the dimensions of my current box) with 2 external aeroports that can fire through the holes where my rear speakers used to be in the rear deck (is that an affective setup?) i have a 95 cadillac seville sts and the trunk is extremely sealed.
ok, so far i have figured that with 5.3^3ft (taken into account subwoofer displacement) and using 2 aeroports... the Diameter would have to be 5" and the length would have to be 6.39" and that should give me a tuning frequency of about 45Hz.
so is that correct? is there any leniency on the length of the port with out affecting tuning frequency?
Old 01-14-2010, 01:18 AM
that is tuned very high
unless this is a 4th order
Old 01-14-2010, 01:20 AM
0/11 sssssss34
no, AudioQue HD3-15... sounds amazing at that frequency. percise and loud
Old 01-14-2010, 01:22 AM
0/11 sssss6075
Yes we've used HDC3's before..
Old 01-14-2010, 01:26 AM
0/11 sssssss34
huh?
Old 01-14-2010, 01:28 AM
well if you like it that way more power to you
I hated my aq tuned to 40hzhad to drop to 35 to flatten it out
Old 01-14-2010, 01:36 AM
0/11 sssssss34
so that is correct than? and is there any leniency as far as length goes with out affecting the tuning frequency? i mean i figured it to have a length of 6.39" i can i round it to the quater inch, say 6.25" with out affect the frequency?
Old 01-14-2010, 01:46 AM
I'd go 7" you need to take out for sub
Old 01-14-2010, 12:34 PM
98AckCL23's Avatar
0/11 sssss9929
It looks like you've already subtracted the sub's displacement, which is good. That being said, any change in post length will effect your tuning. Same thing as being off in your volume calculations by any bit. The last box I designed (my own current box) I was only off on the volume by like 2 cubic inches. That was good enough for me, but I know it did effect my tuning by maybe .001 hz or something like that.
Also, if you're trunk's pretty well sealed, why not just make a 4th order, ports through the deck (like you're planning) and seal it off completely? It would definitely cut down on your trunk rattles, and should help it get louder in your car. Just a thought...
Team Concepts
Team Shok
Ohio Bass Society
Team XS Power
Old 01-14-2010, 12:53 PM
0/11 sssssss34
i have no idea how to figure out how much volume there should be in the different chambers.
FYI-Future-Star bumpin buick Talk with the staff 15 10-29-2009 04:08 AM
My future plans bumpin buick Talk with the staff 7 04-09-2009 02:23 AM
Email from the future....past...err...idk tater Off Topic Chat 2 02-11-2009 05:29 AM
