Port Help Please - Car Audio Classifieds!
Old 01-21-2010, 04:32 AM
0/11 sssssss22
Default Port Help Please
Port Help Please
Hey everyone, I'm building a DIY sub in a 10.33 cubic foot (hopefully 9.35 net) enclosure with a Dayton audio reference high-fidelity 15". I guess the figures you would need to know are 14mm xmas and it should reach that at around 300 watts in this enclosure. It will be tuned to 18 hz. My friend with a lot of sub knowledge recommended a single 6" internal diameter port with a length of 20.5 inches. The problem is I really don't like the look of a single port. My options with WinIsd mach calculations include: (4) 3" ports 19" length .02 mach. (2) 4" ports 19" length .05 mach. (2) 4.5" ports 24.5" length .04 mach. Finally, the least desirable, 6" port 20.25 length .09 mach. I can't find any of these sizes online with a length as long as any of the ones listed, longest I've found is 17". Anyway, I really could use some help as I guess there are some variables I don't know about? Anyone know where to get longer ports than 17"? Thanks guys
Old 01-21-2010, 09:49 AM
jwesenick79's Avatar
not loud yet
0/11 ssssss882
would regular PVC pipe work for what you're trying to do? unless this is for aeroports, then you could get thin-walled pvc i believe.
149.4 dB and climbing....
18" Solo-X, Shok Industries 3.5k and two 100.4s, 250 amp Mechman Alt, 4 runs shok competition cable. TEAM SHOK - WI
Old 01-21-2010, 10:47 AM
0/11 sssss5305
assuming this is for HT then sonotube or PVC will be fine as that's what most guys use. I run 2 15's each one in 10cubes with a single 8" sono and get no port noise. 19Hz tuning and 400watts per sub.
Old 01-21-2010, 12:24 PM
not loud yet
0/11 ssssss882
wow, 10 cubes per 15" sub? Mine are only 3.5 cubes per 15, with a single 3" aero tuned to 16 hz lol.
Old 01-22-2010, 05:34 AM
0/11 sssssss22
Yeah 10 cubes, hah. Winisd originally wanted 11.37 for optimal response but that is ridiculous big.
Old 01-22-2010, 05:36 AM
home theater is completely different then car audio
I love big sealed boxes for HT
but to answer your question sonotube and pvc work great for ports
Old 01-22-2010, 05:39 AM
0/11 sssssss22
The driver did pretty bad in a sealed box. The recomended net cubes was I think just over 5. This whole damn project is a huge mess. I can't even get past the design phase of it. ugh.
port ? gbo559 Enclosure Discussion & Design Construction Help 15 01-05-2010 03:18 AM
Port Gamble Car Show 2009 to Benefit Breast Cancer ~ Port Gamble WA ~ 08-29-2009 CACO's Car Show Bot Car Show Feeds 0 08-17-2009 03:00 AM
Port help please Team3d Enclosure Discussion & Design Construction Help 2 04-07-2009 08:23 PM
