is this to much? - Car Audio Classifieds!
Old 01-23-2010, 12:27 AM
0/11 sssss1380
Default is this to much?
is 20 square inchs of port per cube to much? 2 12s in about 4.8 cubes tuned to 36 with about 2 cubes per square inch on about 2500 rms each would give subs specs but... there under "wraps" till next month or so
Old 01-23-2010, 12:36 AM
it could be and it could also be right
the only way to be sure is to test it
Old 01-23-2010, 12:39 AM
0/11 sssss1380
alright im going from 4 10s in a 6th order to 2 12s in a more efficient box.. hoping to gain with a more efficient box well see what happens!!
thanks for the help!
Old 01-23-2010, 12:51 AM
0/11 ssssss567
pssh. just go for 4 12's
08' VW GTI BMP
Old 01-23-2010, 12:53 AM
0/11 sssss1380
thought about it dont have the room to do it bearly have enough to do teh 4 10s the stype box i have is the only way to fit 4 10s with port and subs firing into the car
Old 01-23-2010, 02:44 AM
0/11 sssssss22
What subs?
Old 01-23-2010, 02:48 AM
the bigger the port the less control you are going to have unless you cut down on box size, really it's just a big trade off you will have to find what suits you best. I ran my l7's with 30" a cube once and it did just fine
