what did i miss (kerf cutting) - Car Audio Classifieds!
Old 11-06-2008, 01:44 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
Default what did i miss (kerf cutting)
so my last box, the one you can see in my F/S thread for the BM's, i was going to try a kerf port. tried on a test peice that was 6" wide. i got it diled in with 1/2" spacing and within, oh, less than a 1/8" from going though. bent perfectly to what i needed. used it as my guide for highth so i would get the same depth, and the same 1/2" spacing. couldn't get it to bend at all. went over it again a little deeper, and that time it broke. so what am i missing here?
Proud Member of CAAA!
Old 11-06-2008, 01:46 PM
0/11 sssss9745
Moving to enclosure forum...
Old 11-06-2008, 01:59 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
oh snap, I didn't even see it. Thank you sir.
Old 11-06-2008, 02:59 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Could just be a defect or problems in the tolerance of the MDF, maybe even some other outside factor.
My Car, My Ears.
Old 11-06-2008, 03:10 PM
SPY SPY is offline
0/11 ssss10192
Feedback Score: 93 reviews
Any pics of the cuts?
/ CAAA Member #2 /
Old 11-06-2008, 03:11 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
could be have a few leftovers of the same size here I might try. I see spy in here, what's u think sir?
Old 11-06-2008, 03:12 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
over on ca I have some. It's in my build log. I can't link from here, but it's in the log section.
Old 11-06-2008, 11:19 PM
0/11 sssssss37
how wide is the blade? maybe you're trying to bend it on too tight of a radius.
Old 11-06-2008, 11:37 PM
SPY SPY is offline
0/11 ssss10192
I can't really tell anything from those pics.
I think you probably need to work on your depth. Play around with some more scrap pieces and see if you can get it. If your still haveing trouble post some pics of the side of the wood so I can see the depth you are cutting.
Also check the width of your blade, you might need more cuts closer together. I usually do 16-18 cuts about 1/4" appart for a 3.5" radius kerf.
/ CAAA Member #2 /
Old 11-07-2008, 12:40 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
makes since. If I get. A chance Monday I'll try to play with it some more.
Two Fi 18's with BP in Suburban HELP "KERF IT UP" jdubbau Box Requests 3 11-12-2008 08:34 PM
How do Kerf Ports....... only126db Enclosure Discussion & Design Construction Help 14 11-10-2008 11:52 PM
Manswers!... this show is amazing! how did i miss this? Patrick Simmons Off Topic Chat 3 09-18-2008 09:40 PM
