Box for my HDC3 10's & Alpha V.2 - Car Audio Classifieds!
Old 12-13-2008, 06:46 PM
0/11 ssssss888
Default Box for my HDC3 10's & Alpha V.2
Well, i am going to do some comps this coming spring and was wondering what box i should use for spl. I have two HDC3 10's i will be using for street A. I was thinking right around 1.5ft^3 per sub @ around 40-45hz. Im Gonna be feeding them around 1500 a peice btw. I figured i will learn from you that have used these. I am not worried about SQ at all, i have an alpha v.2 that i will throw in my car.
Also, i am going to have an alpha v.2 that i will put in when im not at comps for more SQ. I want some Bump out of this too. Its just a single 12". I was thinking aroung 2.5ft^3 @ 34hz. Seems like a standard box that will have decent sq while getting loud as well.
Btw, this is a 99 lumina. I have about 30in of width and i dont wanna go any higher than 12" for the 10's and 15" for the single 12. Thanks for any advice!!!
Old 12-13-2008, 07:25 PM
0/11 ssssss483
if it is strickly SPL then do 50-54hz and about 1.3-1.7^3 each sub. should put up very nice numbers.
Old 12-13-2008, 07:59 PM
0/11 sssssss49
1.6 cubes @ 38 hz was loud as balls for my 10" hd3c
Old 12-13-2008, 09:20 PM
0/11 ssssss888
Ok, well i may do 50hz at 1.6. That way i take both of your guys advice. lol. Im really hoping to get at least 148... Well see tho. I may build two boxes for the subs as well. One ported low and one high, and sell the alpha. My friend is interested. What programs would you suggest i use for the box.
0/11 ssssss888
You ever meter it?
Old 12-15-2008, 08:09 PM
0/11 ssssss888
Any one else got thoughts Im getting the RD alpha tomorrow. So lmk what you think.
Old 12-15-2008, 08:27 PM
what does your car peak at?
Old 12-17-2008, 05:56 PM
0/11 ssssss888
Huh, not sure what you mean!
Old 12-17-2008, 05:57 PM
what frequency is loudest in your car
Old 12-17-2008, 08:05 PM
0/11 ssssss888
Idk, how would i find that out. Just experience?
[SOLD] F/S AQ HDC3 18's!!! RE_Gawker 18" Subwoofers 21 12-17-2008 01:04 PM
[SOLD] AQ hdc3 15 iamtheone 15" Subwoofers 19 10-29-2008 07:56 AM
Box build for 12" AQ HDC3 SPY Off Topic Chat 8 10-18-2008 12:03 AM
AQ HDC3 10" box build SPY Off Topic Chat 10 08-29-2008 03:23 PM
Box build for 2 RD alpha 10's SPY Off Topic Chat 14 08-21-2008 11:55 AM
