for ridnclean - Car Audio Classifieds!
Old 12-14-2008, 09:52 PM
Default for ridnclean
well I'm not sure if you got my pm's so here they are threaded rod for bracing not shown and both must be built inside car
12.9 ft tuned to 32hz 281" of port
14 ft tuned to 33hz 290" of port
more to come soon
Old 12-14-2008, 09:56 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
i got your PMs
i'm diggin the designs!
more to come? cant wait!
92 Ranger Walkthrough
(Under Construction)
Old 12-14-2008, 10:02 PM
the second one caught me off guard I didn't think I was gonna be able to get all 4 to fit in a flat wall also the specs I listed here for tuning and port area may be slightly different than the actual model as I wrote them on here by memory they arn't off enough to make a difference just a heads up though
edit: I also forgot to tell you there is only about 5" behind the wall
Old 12-14-2008, 10:05 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
i really like the 2nd one.
i doubt there will be cancellation, but it scares me there might be lol.
Old 12-14-2008, 10:06 PM
slammed636's Avatar
0/11 ssssss692
diggin the first one!
Old 12-14-2008, 10:08 PM
yeah I like the way it looks but I gotta redo it later because I'm an idiot and forgot to save it when I started the second one
Old 12-14-2008, 10:09 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
no doubt, 1st one would be iLL lookin, definitely a show-off
DLP customs
Guest
0/0 sssssssss
Watch the xmax of the subs on the 2nd one, the 4th one should be the loudest howie.
Old 12-14-2008, 10:13 PM
ok 4 12"s tuned a little higher at 37" but you can plug one or more ports for daily 8ft this box is 1.25" thick (.5and .75 glued together)
If anybody has the fs, vas, and qts of the omega's in 12" and 15" please post them up I wanna see If I can get a 4th order to fit
Old 12-14-2008, 10:14 PM
yeah I had to guess on the x-max as no specs on website so I just set the to baffles 2.5" apart from each other in the back
