Box Design(2 15" Mtx 9500's) - Car Audio Classifieds!
Old 07-13-2010, 06:43 PM
hondaonchrome's Avatar
0/11 ssssss153
Default please close???????
PLease close
Thanks,
Lonny.
Old 07-14-2010, 02:14 PM
apbt55's Avatar
0/11 sssssss76
I am stealing an idea off of mistrass. I just got 15's and have 2 inches more height, but will be cutting out some useless sheetmetal and sealing off my trunk. I will have an 8.5 cube box tuned to 32hz with about 99 square inches of port.
I know he has the build log for his altima on caraudio.com, but not sure about on this site.
http://www.caraudio.com/forum/genera...ld-pics-2.html
You are starting out with about 7.9 cubes gross, say about 0.4 for your sub displacement gets you to 7.5, you could do a 14.5 by 6 port which depending around tuning will get you to around 6 cubes net.
Just remember you will need to get the box in the car.
don't know if that helps
2004 nissan altima, 3.5L
275 amp DC power HO Alt, KHC1400 under hood. C&D UPS12-475-FR in back.
JVC Arsenal KD AHD59
AQ2200d (back up Soundstream PCA1500D)
MB Quart DSC4125
Crunch P1800.4
RF T1692, RF T1652-S in front, RF T1652 in rear door.
2 AQ SDC2.5-12 in ported box.
Old 07-15-2010, 03:52 AM
0/11 ssssss153
I thought about doing it like yours and cutting the rear deck to make it fit and then re-weld it back in.
thanks for the comment
Old 07-15-2010, 04:19 AM
0/11 ssssss153
Mtx recommends 2.48 net enclosure per sub(from there website)(W 24xD 17xH 16)Port 2"x14.5.
Now my trunk dimensions are 40w x 26d x 16h so i think i can make this work in my trunk...Right?just by taking 4" off the width and adding it to the depth and then make a 4" port........Can someone help me out with this....PLEASE??lol
I listen to mostly rap and rock(for port tuning)
Which of the following is the sub displacement?That would have to be minused off the 2.4 net volume right?
Fs:
30.60 Hz
Qms:
3.68
Cms:
0.071 mm/N
Mms
379.00 g
Rms:
19.80 kg/s
Vas:
2.661 ft³ (75.33 liters)
Xmax:
1.010 in (25.65 mm)
D:
13.081 in (332.27 mm)
Sd:
134.40 in² (867.10 cm²)
Vd:
135.76 in³ (2.22 liters)
Qes:
0.68
Re:
3.66 Ω
Bl:
19.88 Tm
Prms:
1000 Watts
Qts:
0.570
ηο
0.308 %
SPLo:
87.09 dB
SPL 2.83V/1m:
90.38 dB
Old 07-19-2010, 03:40 PM
apbt55's Avatar
0/11 sssssss76
Vd would be sub displacement,
so around 0.08 cubic ft per sub. seems kind of small for a 15,
If you listen to both rock and rap tune to around 35hz.
MB Quart DSC4125
Crunch P1800.4
Old 07-19-2010, 03:44 PM
jwesenick79's Avatar
not loud yet
0/11 ssssss882
i say dont do the box mtx says, i did one for a friend to their specs and it isnt nearly as loud as it should be in my opinion. i thought it was too small too
149.4 dB and climbing....
18" Solo-X, Shok Industries 3.5k and two 100.4s, 250 amp Mechman Alt, 4 runs shok competition cable. TEAM SHOK - WI
Old 07-20-2010, 03:32 AM
0/11 ssssss153
So do you guys think 2 subs will work in my trunk?
Is there any pro's vs con's?
Im trying to get loud!!!!....lol Would 1 be louder than 2?
Amp will be an audiopipe 3000.1
Thanks,
Lonny
Old 08-20-2010, 07:51 PM
0/11 ssssss153
After doing some more measuring i was thinking about doing a wedge style enclosure sub baffle flat 16"h and the wedge(angle)will be against the trunk lid,im trying to get the most airspace as possible so i think i will add a aero port....what do you think??
Baffle H16" x 38"W x D(bottom peice)32" x D2(top peice)31" x wedge(angle peice)18"
I played around on 12volts box calculator and it seems to be roughly 9 cubes total....does this sound right
Can someone give me some input and or suggestions and maybe a box design?
Thanks for any advice.
Lonny.
Old 08-20-2010, 07:58 PM
0/11 ssssss153
Maybe someone can help me build this......if anyone is experienced with building these and could help a fellow out let me know......
Old 08-22-2010, 05:07 AM
0/11 ssssss153
What is the better calculator to use re's or 12 volts?
[SOLD] 12" mtx 9500's Rd4me 12" Subwoofers 5 11-26-2009 08:03 PM
box design for two 10" RD Classic fracl Off Topic Chat 20 09-04-2009 01:03 PM
Box design request for 4 18"FI ssd 4 18"FI ssd Box Requests 7 07-14-2009 07:33 PM
AudioQue HDC3-A 15" vs Digital Design 9500g 15" redrum General Car Audio Discussion & Questions 9 07-09-2009 12:52 AM
can anyone design me a tl for mt 10" oem? Lance_aka_64 Enclosure Discussion & Design Construction Help 5 11-08-2008 05:36 AM
